RT @gclue_akira: レースまであと3日。今回のコースは激ムズかも。あと一歩
#jetracer https://t.co/GKcEjImQ3t
RT @chr1sa: The next @DIYRobocars autonomous car race at @circuitlaunch will be on Sat, Dec 10.
Thrills, spills and a Brazilian BBQ. Fun…
RT @araffin2: 🏎️
After hours of video editing, I'm happy to share a best of my Twitch videos on learning to race with RL.
Each part is…
BUT there is NO proportional AUX channel at all, there is a 3 position one, and the rest are only on/off.
I would suggest going for Futaba if your wallet can survive it, I have the RD8000 because I got it cheap and I refuse to put my whole budget on a TX.
The RD8000 will work with ArduPilot since you can set the throws of the switch positions to regulate the FMA co-pilot but this is less than handy as you can immagine.
According to RDS8000's manual failsafe can be set on CH1 through CH4 - I thought that would be sufficient (is it???)
Futaba 9C is a bit out out my budget :( (it is a nice TX though)
1. I believe the 2.4ghz FASST system is superior to the DX7 system since it is constantly frequency hopping while i believe the DX7 just scans and picks two frequency available at the time and uses them for the duration of the flight (or so i have been told)
2. The 7c is supported by all current head trackers (MagTrack, TrackR2) if you want to use it for fpv in future.
Regardless of what you choose, make sure it has a failsafe on all channels, not just the throttle.
You will need this to activate the ardupilot in the case of signal loss.
If you can afford it for with a FM/PCM Futaba 9C, they have two more channels, i believe has failsafe on all channels and has a module so you can upgrade to 2.4ghz later if you want. I still use PCM (I use a 2.4ghz video system) and haven't had any problems.
Hope this helps.
Nick
Since I wasn't getting much replies here I posted same questions at rcgroups - hopefully it can benefit other people in same predicament as mine..
http://www.rcgroups.com/forums/showthread.php?t=984307
I have a DX7 and love it. Got it 2 years ago and wouldn't look back. Futaba may be a bit better though as they use a different technology than the DX7. can't get into too much detail right now...would have to re-educate myself. Airtronics is lower priced if I remember correctly and you get an extra channel. I think they use frequency hopping...
I believe that any 2.4 gig radio would be worth the investment. Why worry about some kid at a park crashing your aircraft because he's on the the same channel.
