Hi all, I've been using a HoryzonHD camera for FPV and aerial HD video. All of my video recordings have a weird wobble to them, although I don't notice this in FPV. Do you think this is likely to vibration, or some kind of electrical interference? Here is an example:
My setup looks like this:
The camera is powered by a dedicated BEC. Sources of interference I can think of are the battery cable, GPS (I have the big UBLOX), and my xbee pro. There is a ~8cm unshielded cable between the camera and the recording unit. The recording unit is lit up because it has a screen with backlight, but this is turned off when I fly with it.
Any ideas appreciated to speed up my troubleshooting!
Thanks,
Aaron
It's called "jello"...induced by vibration from the motors/props. It seems that most folks can eliminate this by using a camera mount that is isolated from the main frame by soft rubber-like washers and such.
But yes, balancing props helps as well.
Here is a link to a discussion, there are many others:
http://www.rcgroups.com/forums/showthread.php?t=1592008
