At Mission Planner, under Configuration, there is an option to choose a video input.
Sometimes I use a EasyCap card and I can get the video back of the artificial horizon in Mission Planner.
But the recording options are limited to 5 frames per second, then the video is not smooth, showing a terrible lag.
Is there some form of increase to 30fps?
Or, please moderation enable this option in the next updates!
I think the problem is that MP expects a MJPG stream and Easycap doesn't support this.
any new on this topic.
I have also an Easycap Device,
Missionplanner is only showing 5fps as video format.
CPU is an I7 - so CPU sholud not be the problem
thx for help
Florian
how fast is the pc you are using? the planner trys to record at 10 fps. but that depends alot on the capture device.
