wireless GPS data transfer through MAVLINK and PIXHAWK
Hello everyone
I'm facing the following problem: a stationary (on the ground) GPS + an arduino MEGA + an RF link at 433MHz configuration, produces,  parses, recombines and transmit through the RF its GPS position in the format:
<ID,11.111111,22.222222,33.33,hh,mm,ss,iter\n>
where: ID: a 4-digit identification nr for the transmiting station
: 11.111111,22.222222,33.33 the Lat,Long and Alt respectively for the GPS
:next is the time and then the number of iteration.
This configuration is located away from the ground station, in an unknown location.
The RF link is a 3DR, 433MHz with serial and microUSB output for the receiver. The receiver of the RF link is on a drone, using a PIXHAWK uC.
Can someone please suggest me a way to interconnect the RF receiver on the drone to the PIXHAWK in a way that the received information in the above form to be retransmitted as-it-is (or alternatively, after parsing it) to the ground station (A windows 7 PC, running MP) through telemetry? I'm also using python code to control the vehicle through MP.
Thanking you in advance
  • Thank you Chris! I'm thinking the following solution: to use an ARDUINO on-board on the drone, receiving in one of its serial ports the above string (<ID,11.111111,22.222222,33.33,hh,mm,ss,iter\n> )
    the uC with the suitable software will parse the string again. Through a second serial port the uC will communicate with the serial4/5 of the PIXHAWK sending one-by-one the elements of the string. Is it possible to read then through MAVLINK these elements on the ground station?
    It's the latter. It's easy to use the built-in MAVLink protocols to transmit and receiver GPS data, but if you want to create custom strings you'll need to write custom code.
    Ioannis said:
    After 100(!) views, NO REPLY means: either my question has an obvious answer, either it is very difficult to find a solution to the requirement? What is going on guys??????????????????
    Hello everyone I'm facing the following problem: a stationary (on the ground) GPS + an arduino MEGA + an RF link at 433MHz configuration, produces, …
  • After 100(!) views, NO REPLY means: either my question has an obvious answer, either it is very difficult to find a solution to the requirement? What is going on guys??????????????????
