MR60
World Record for Duration of Flight
3689563453?profile=original
1 hour 20 minutes
- APM 2.5 takes the world record for Multi-Copter Duration of Flight powered by a rechargeable battery. [note:  records also exist for hover that can occur indoors and take advantage of ground affect]
Flight Requirements:
- Distance > 1 kilometer
- Minimum elevation from ground the greater of 2 meters or two prop diameters (no ground affect)
- Lands within 50 meters of Launch
- Minimum of two way points > 0.25 km apart
- Altitude Climbs: Two climbs > 100 meters each
- Ends before voltage drops below recommended minimum level for recharging
- Flight over ground that does not vary more than + 20 meters in elevation
Actual Flight
- Distance: 1 - 2 km
- Min elevation 2 meters
- Ended at start
- Three way points with two 0.3 km apart
- Two climbs:  126 meters and 112 meters
- 13.06 volts left with 10 volt recommended minimum
- Ground + 10 meters
Time:  > 1hr and 20 minutes (81.43 minutes)
Multi-copter:
- Octa 2XQuad 6Up+2Dn (wanted to fly something novel that would show off the flexibility of APM 2.5)
- 3.18 kg AUW
- Li-Ion battery
Attached are the flight logs.  Later I'll provide:
o Video
o Earthview of flight
o Altitude gains
o Details of the copter (design and weights)
2013-11-26 11-41 187.kmz
2013-11-26 11-41 187.log
2013-11-26 11-41 187.log.gpx
  • Great Work Bro!
    My gransond and I will try to beat your record except with a quadcopter in January.  If Oliver reads this, perhaps he did not realize that helicopters are two rotors or less.  Multicopters are more than two rotors by definition.  I also agree with you that the record should be repeatable and we will disclose the build and will abide by your record setting criteria as follows:
    two climbs of  > 100m each
    rechargable batteries for all multicopter power needs
    > 2 m agl entire flight except for takeoff and landing
    land within 50m of takeoff point
    >2km flight with two or more waypoints >0.2km apart
    terrain less than 20m highest to lowest elevation
    Due to the difficulty of filming the flight, we intend to document using the FMS.  If we cannot break your record perhaps we will set a quad record.
    Jim and Max too
    The Merriam-Webster dictionary defines a "world record" as : a record officially recognized as the best established anywhere in the world - a definition I think we all agree is relevant.
    As this flight, while very impressive and noteworthy in itself, has not been officially recognized by any authority or body it cannot be called a "world record", a record absolutely but not a "world record".
  • Forrest that duration is simply amazing!  Especially with all the altitude changes.  Did I miss something or could a lot more flight time have been attained without the extra energy up and down, etc...Why didn't you just let the APM fly 3 way points in cruse control (at some average efficient flight speed) and keep altitude constant over the field?  Or did you just fly manually?  Your Octocopter is the most elegant design I have seen  Love it.
  • 300km
    Hi Forest
    I'm trying to fly my fixed wing 100km
    http://diydrones.com/profiles/blogs/anatomy-of-a-100km-attempt
    I'd love to know more about your battery pack. I see you used a 4S10P layout, but can you give more details about how you connected them?
    Did you solder directly to the terminals? What were the nickel tabs?
  •  Stunning ,well done .
    J.C.
  • So this is a world record for your own requirements? I suppose I could make thousands of world records be that the case. I find it funny that you took EndOfDay's idea for the battery pack and then claim to have a longer duration flight than him based on some arbitrary rules.
  • At this moment i am thinking Building something like this
    frame:
    CarbonF H8 (same as X8 with 8 motors)
    motors:
    Pulso U39M 280KV weight;57gr. efficiency (Gr./W)12.20 at 14,8V 530 gr.thrust 1.9A current
    http://www.pulsosystem.com/u39m-280.html
    propellers:
    bigger than test but is possible for better results
    http://www.himodel.com/plane/18x_5.5_Heavy_Duty_Carbon_Propeller_Se...
    batt:
    SHORAI LFX Lithium-Iron Powersports battery LiFePo4
    18 000 mAH  27C(270A)discharge  weight:1Kg  w.Protection case
    Lithium-Iron technology LifePO4
    • Ultra light – 1/5 the weight of lead-acid batteries
    • Up to four times the service life of lead-acid batteries
    • Faster cracking for better starts
    • Carbon Composite Case
    • Japanese engineering and components
    • Hold unloaded charge for one year without maintenance
    • Super-fast recharge rate wit Shorai charger
    • No explosive gasses during charge, no lead, no acid
    • Zero sulfation
    • Environmentally friendly
    • Three Year Warranty
    http://shoraipower.com/lfx18l1-bs12-p94
    2.5 kg RTF
    4-5kg AUW
    flight time AUW 30-40min
    Any sugestions?
  • Unsubscribe
    Hi Forrest,
    World record thing aside, this is a VERY impressive accomplishment! And the full disclosure is awesome. The 2 hour flight referenced above doesn't even get on the list for lack of disclosure (and the hearsay dropping of batteries).
    Hats off to you!!! I look forward to seeing the results in summer.
  • 1:20 Is amazing no matter how you slice it.
