X-Plane simulator / APM 2.0 problem
I need your help. I am a novice owner of APM 2.0
Using the X-Plane simulator. I can control the RC model of equipment but I can not run on autopilot (Auto or Stabilize mode ) while I mission planner set parameters.
You can write to me what I did wrong that it did not work. I uploaded model Parm. Annex two photos. The first general settings. The second is a description of the APM 2.0 out controls.
I use Mission Planner 1.2.35 mav 1.0
Arduplane V 2.68 (2.70 did not work - I coudn't connect corectly - Conection error).
  • I meet the same problem , if anyone can help ,please write to me   thanks
    my email:  87040109@qq.com
    • Hey QQ,
      I know it was a while ago, but did you find a solution to the problem?
      Cheers
  • APM is connected to the channel 6 to the receiver.
  • Hi Majkel,
    Are you using X-Plane 10?
    I am currently flying X-Plane 9 on an APM1 using Arduplane 2.68 and MP 1.2.35 mav 1.0 with no problems.
    I notice that you have no GPS fix, have you enabled the GPS on the configuration page of Mission Planner.
    Do you have full control when you fly in manual?
    Martin
