X8 camera Gimbal for Canon SX 260 NDVI Camera....
Hi.  I've been reading through the comments related to this topic and have yet to find anyone that has found a compatible gimbal for the X8.  I hacked up a universal gimbal and it works ok, but not even close to what I need in terms of stability.  In case I missed it, does anyone have any good working solution?
As always, thanks for the help.
- David
            • Sounds like a plan.  Thanks.
          • yes will work for you same style camera as the NEX, that is 291 grams and Canon only 208 grams if you want to be technical.
            • You're awesome.  Thanks.
          • Any NEX 5 gimbals work, but you need to put extensions on the legs. The screw mount is on the opposite half of the camera (left side vrs right side of bottom) but for a universal like the above it doesn't matter.
            • Ahhh, that helps.  Thanks.
  • Skywalker X8 or a X8 multicopter?
    • Hi Tommy.  It's a 3DR X8 Multicopter.
