10 properties shot in under 2 hrs - SteadiDrone H6X
3689487491?profile=original
Hey again all, just a quick one. Just come back from a very quick aerial shoot for a local real estate firm, we covered 10 different properties from the air with our SteadiDrone H6X, such a pleasure working with it, fast and effective.
On the SteadiDrone H6X we're running the T-Motor 4008 and a single 5000mah 4S, which gives us very good flight times, but still light and nimble, the 380kv motors spin so slow withthe 14" props, it's ultra quiet and efficient, we were shooting in a residential aera (with a lot of older people) so the losw noise and small size really is very un-obtrusive and hardly noticable. Shooting the Canon S100 + CHDK it's simply a matter of, out the boot, plug in, wait for GPS lock, up, loiter, snap snap snap, land, next property!
Having loiter in manual alt mode is great as once you're up you can stick on the goggles, frame the shot and lift or drop the drone depending on what you need to capture, could not be easier. Now again, yes the SteadiDrone is a really nice piece of kit (comes full RTF with EVERYTHING!) (yes I own SteadiDrone) but as I've said many times before, APM is our backbone, and from the very begining when we started out, I still, to this day do not undrstand why people are using anything else, it's affordable, simple, easy to use and get into the setting code (try YS-X6!!! omw..) It's VERY reliable and handles slow spinning motors with big props (try this on DJI..) The code has come of age and I still think it's by far the best FC out there, thanks again to all the devs who make this wonderful piece of hardware/software work.
Here's a quick shot of the SteadiDrone H6X (more info at http://www.steadidrone.com/index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=2&virtuemart_category_id=1)
and also two shots from the shoot this morning.
3689487702?profile=original
3689487631?profile=original
  • hi Tod, i sell the tiger motors in NZ the 380kv was added about 3 months ago bu supply has been very limited.  i actually got a set of 8 in the other day have not had a chance to put them on a machine yet.
    im sure you have seen the new Navigator series.   in there they have a 4012 that is right down to 340 kv and looks awesome specs on the site indicate  that they will do 810 g of thrust at 3.2 amps at 50% throttle that almost 5 kg of lift and only drawing 18 amps on a hex.
  • I've been using lower kV motors for the last couple of years now.  Far better performance for AP.  The lower kV motors generally have a broader voltage range, which makes adjusting for wind conditions a little easier.  Its easier to change battery, prop and PIDs' than motors.
  • As with many of their motors, they make this one in 600 and 380kv. The lower / bigger props, the better. Keep in mind that the lower kv, slower spinning, bigger props require a really good quality airframe and stability setup, it's not as 'nippy' as smaller props, higher kv, but far better for smooth aerial AP and flight times.
  • I sell T-Motors and all the 4008 motors I have are 600kV.  Interesting.  I will have to get in touch with Julia at Tiger Motor and inquire about these.  The lowest kV I've got in the T-Motor is 400kV.  Be worth trying.
  • Nope these are 380kv and running 14" APC on the H6X runnign 30A and 5000mah 4S, it's sooooo smooth and quiet and will get up to 20-25min on a single lipo
  • Isn't the MT4008 600kV, or are those a custom kV?
  • Very nice!
  • 100KM
    The dream achieved, well done.
  • 3692551169?profile=originalSteadiDrone QU4D, packed and read for shipping in the included PeliStorm case :)
