3689592450?profile=original3689592468?profile=originalUblox company start producing 18Hz 72-channel GPS/QZSS L1 C/A, GLONASS L10F BeiDou B1 SBAS L1 C/A: WAAS, EGNOS, MSAS receiver
  • Receiver type
    • 72-channel u-blox M8 engine
    • GPS/QZSS L1 C/A, GLONASS L10F
    • BeiDou B1
    • SBAS L1 C/A: WAAS, EGNOS, MSAS
  • Navigation update rate:
    • Single GNSS up to 18 Hz
    • Concurrent GNSS up to 10 Hz
  • Position accuracy: 2.0 m CEP
  • Acquisition (MAX-M8Q,W/ MAX-M8C)
    • Cold starts: 26 s / 27 s
    • Aided starts: 2 s / 4 s
    • Reacquisition: 1.5 s / 1.5 s
  • Sensitivity
    • Tracking & Nav: –167 dBm / –164 dBm
    • Cold starts: –148 dBm / –147 dBm
    • Hot starts: –156 dBm / –156 dBm
  • Assistance
    • AssistNow GNSS Online
    • AssistNow GNSS Offline (up to 35 days, requires host integration)
    • AssistNow Autonomous (up to 6 days)
    • OMA SUPL & 3GPP compliant
  • Oscillator
    • TCXO(MAX-M8Q/M8W),
    • Crystal (MAX-M8C)
  • RTC crystal: built-In (MAX-M8Q/M8W)
    or cost efficient solution with higher Backup
    current (MAX-M8C)
  • Anti jamming: active CW detection and removal
  • Memory: Onboard ROM
  • Supported antennas: Active and passive
  • Support tools:
    • EVK-M8N: u-blox M8 GNSS evaluation kit
      with TCXO, supports MAX-M8Q/M8W
    • EVK-M8C: u-blox M8 GNSS evaluation kit
      with crystal, supports MAX-M8C
We have designed small boards for this module test. I will test this modules next 2-3 days.
  • Hi,
    Where is your shop located at?
    The About Us page shows nothing, and the map does not really reveal that information either.
  • you can check csgshop.com
    Lock with 18 SV Channels, very nice, when will these be available and cost?
  • We have make today receiver test. Test duration 20 min deviation less than 1 meter!!!
    3689592819?profile=original
  • Is it compatible with the 3DR config file: http://copter.ardupilot.com/wiki/common-ublox-gps/
  • This data avail only from LEA-6T or NEO-6P modules.
  • Does it (or can it) have raw timing data and carrier phase L1?
