Just completed the assembly and setup of my new 3DR X4. I am using all 3DR parts including:
- Pix Hawk
- GPS/Compass
- 915 Mhz Tele,
- 3DR Power Module
- 3DR 850 Kv 28/30 Motors
- 3DR Simon. K ESC
- APC 10 X 4.7 Props
- FrSky Tx &Rx
- GCS
- Nexus 7 running DroidPlanner 2.0
I have completed my first flight using the default X4 Param. It was stable but I wanted it to have a more locked in feeling so I performed the Auto-Tune and all I can say is "WOW", really nice. I have made a mount for a digital camera to be mounted to the bottom for Ortho-mapping small areas. I use a Canon Elf 115 with CHDK for USB remote triggering by the PixHawk. Works great....
The DIY frame kit is excellent. It even included locktite. Great quality and it goes together nicely.
Thanks 3DR for such a great product....
Joe Millette
Went the inverted prop/motor route on my X4. Still have to tune it. Rolls left during takeoff and sometimes wobbles during flight.
I recently had a controller issue with my pix hawk that put a hold on testing. Still trying to figur it out.
I completed a normal auto flight from take off to landing then I restarted the mission without turning off the copter. When I raised the throttle to start the auto flight it became unstable so I stopped the flight. I looked at the param file and during the down time it change from x to +. I did not change the settings. I was testing the new 3.2 firmware. I will report back with more data as I discover it.
Sorry for only now responding, my email is Chad@3drobotics.com. Thanks Joseph!
That was my plan too as well.
@Joseph: it would be great if you post this feedback here too. That way maybe everyone interested can learn someting and not only the original designer.
No hard feelings intended, RoboCopter.
As a fellow flight tester of UAS (NMSU\PSL) I would be happy to provide some feedback.
PM me your email and I will write a full report on my findings. I will get the telemetry files from my next flight as well.
Hey Joseph,
I'm really glad you like your 3DR Quad !I was the one who designed it along with the X8 and Y6. We actually explored the option of selling the Quad with inverted motors but after testing them there really wasn't any major difference from the standard config other than slightly more efficient lift at the cost of hotter motors ( because of less airflow over them). I would love to hear more about your experience with your drone, specifically what you like/ don't like about it and what features you wish it had. Thanks!
Don't get me wrong, it is good information. Maybe one day when I have the time I will try to perform a test in a controlled environment and get some data. It would be nice to know for sure on efficiency, but right now I am not extremely interested in it. Right now I am just enjoying flying and having fun. The reason for this hobby. Maybe one day the UAS Flight Test Center I work for will have a reason to test it.
Back in 2011 and earlier i use to put the props on the bottom.
Here you can see on my old DW Hexa, front and back motor was on top and the others were all facing down.
https://www.flickr.com/photos/sidkites/6259277530/
I used this for a number of reasons, for orientation, wash/vibration when traveling forwards at speed.
The only negative effect that this setup had was efficiency.
Moving at speed, a + config is better than a X. Why?
( X + ) just look, going forwards at speed the rear motors / motors have to cope with dirty air from the front motors. If it's a + config then only 1 rear motor has to deal with dirty air.
The large X copter i used had obvious problems with the large props on the bottom because it was trying to pull air through the center of the frame as well as over the boom and mount.
@Joseph, Happy for you to have your props on whichever way you want :-)
Yes i agree the video i showed earlier was shot in a rush, from the last time i had this discussion.
Simon
@ Joseph, of course the props can hit either way. I'm talking about the motor itself. On the bottom, the prop shaft/nut will strike the ground first. For beginner, especially on pavement/cement, this could lead some motor damage. I tipped mine over all the time. But otherwise, I totally agree inverted is probably superior for an AP rig due to noise and vibration.
@ Will, you know I never thought of that in any of the rocket statements. Very good point.
1
2
3
4
of 4 Next
