T3
3km long linear photo stitch
Over the fields.Terminated by fully automated approach loop, as on all my flights (no reason to get nervous anymore).Used 7 waypoints for landing loop and 3 waypoints for the mission itself (overhead 200m agl, remote fixed position at 200m agl, overhead 200m agl then landing).Shoting interval 4.4s, Sony Webbie (that long shoting interval is uncomfortable at lower altitudes for planes flying around 50km/h - photo overlap suffers).Used around 50 photos out of 120 taken (only one direction, all resized down),all in order to save processing time.
Starring:FLEXIPILOT and EasyUAV
  • T3
    I am fully aware of stitching software limitations. This is a different class than GIS software. This time I have obtained results good enough for amateurs and I have posted them.
  • Nice work on image stitching with PTGUI. As commented above it works pretty well with a limited number of images taken over flat terrain. If you need to work with hundreds or thousands of images taken over varying topography you'll need a photogrammetric image processing software which calculates an elevation model prior to rectifying and mosaicking (not just stitching) the images into GE-ready output. If you pick a couple reference points from GE data the mosaic matches GE at pixel accuracy.
  • T3
    I used transparent color, downgraded to 256 colors, imported in GE then resized to my taste.
    Reason: even CNES imaginery in my area has apparently 25m precision (misplaced road etc).
    You cannot get too much precision when importing overlay bitmap to GE, anyway.
    This 3km map is barely fitting and has 40m errors at both ends, (what from another point of view is quite good considering it is 60 images long).
  • When you overlay your mosaics in google earth, do you simple use the overlay tool and make the image slightly transparent and then attempt to match underlying features by re-scaling the mosaic? Or do you have a more sophisticated method?
  • @ T. LeMoine : downloaded MapWindow GIS: I'll give it a try in next days.
  • Thanks Krzysztof and Reto.
  • If you're interested in geolocalizing (or georeferencing) it does not require a full-out GIS suite- I've used a georeferencing program that's part of an open source suite called MapWindow. I've actually referenced some of the pictures I've taken from my plane with this program. I use GE to get the lat/long positions of easily found features in my pictures and input those values as well as precisely pick the point on the photo. I've not done this yet with multiple 'near' photos, but it would probably have a similar 'stitching' effect
  • T3
    For browsing, usually IrfanView or AcdSee.
  • Reto and Krzystof: interesting, I didn't know about GIS softwares nor about GE communities. I'll have a look at them. And what if one's wanting to stitch his / her own images when they grow bigger than 20K x 20K ? What about browsing them without uploading in GE (regardless elevation) ?
  • T3
    So sorry all this was only 2.2km or so.
    3km is here:
    http://www.aerialrobotics.eu/examples/LineMap-s1.png
    The image is 256 colors because I wanted to have transparent border.
    There is a google earth community where you can request adding your map to the global pool, but at the end if satellite imaginery covers half of the country and is 4 years old, they always use sat in order to have better consistency.
    So indeed it must be stored on personal servers as I cannot imagine Google storing all possible small maps from the world for free - they don't have a business model for that task I think.
