In July of 2012 Erik Johnson posted a description of his company's protected-propellers frame prototype. The production model went on sale today. http://safeflightcopters.com/
I wanted to add one extra bit of commentary, I think that one thing that can be learned from this experience is that even though it's a copter, at some point, aerodynamic effects do matter. A lot of surface area far out from the center of gravity has a bad effect on the stability of the copter.
So I finally got around to putting one of my two Safe Flight Copters together so I thought I'd give a short report.
It's a very innovative design and there are not many options out there for copter frames with prop guards but I'm afraid I had very poor luck with this frame. The problems I found were:
1. the installation and shrinking of the nylon netting above the propellers is time consuming.
2. the frame is very brittle. Any small crash and the frame cracks. I even cracked some of the seals picking it up.
3. unstable flying especially if there's any kind of wind. Rough maneuvers especially on the pitch axis could cause the copter would flip over. I suspect an aerodynamic effect caused by the large surface area of the prop guards. I can't 100% guarantee that that's the cause, I was also using a new type of motor that I'd never used before (EnRoute 800kv) paired with a HobbyWing 4-in-1 ESC but I strongly suspect it was the frame. The flips would come especially when flying forward at speed (not even a very high speed) and then flattening out so I suspect that wind would catch under the frame and flip it over.
I managed to get a somewhat stable vehicle (although still far from acceptable) by setting the Rate Roll/Pitch P gains really high (I used 0.25 which is much higher than the arducopter default of 0.15 which is already high for most vehicles).
I was unable to do an autotune on the frame and from reviewing with Leonard we saw lots of little zig-zags in the rotation rate. We estimate these were at about 12hz and we think they're caused by flexing in the frame.
I was thinking all black, with a low lux camera, and some nav lights and bright forward facing lights.. sort of like my profile picture .. which is a TBS discovery frame that unfortunately crashed into a tree...oops.
I have ordered one.
About time someone improved the conventional frame design for more safety and durability. Ordered mine too.
Like all things artistic, the realities of manufacturing usually take over and modify original ideas.
Just in time for the North American shopping season!
-=Doug
The previous models that safeflightcopter has in their web was more beautiful...
Do you have other colors.
Yes, looking good. I've ordered two.
Looking like a very nice platform for quite a number of utility purposes like power-line inspections and wind turbine blade inspection where you want to get in close but if you accidentally touch it doesn't damage what you are looking at or cause you to fall out of the sky.
Actually traversing a mind shaft would be interesting.
oh and wicked fun FPV.
1
2
of 2 Next
