- A Boarduino kit
- Multiplexer and ATTiny chips
- Two 220 Ohm 5v resistors and One 10k 5v resistor
- A surface-mount reset switch
- An extra LED
- A EM406 GPS Module
- A GPS connector
- Three female-to-female RC cables (you'll cut them in half to make the pigtails to the RC receiver)
I'm working on the Autopilot code now, and should have a beta in a few weeks once I've had a chance to test it. I'm starting with a port of the Basic Stamp autopilot, but this board is designed to do much more, so we'll be coding in new functionality like the ability to read a barometric sensor for altitude control and read the FMA Co-Pilot (or custom IR sensors) directly, to integrate stabilization directly into the autopilot.
The surface-mount (SMD) version is functionally identical (except it has two extra analog inputs for sensors, thanks to the SMD version of the ATMega168 chip having more I/O pins), but smaller. We designed this one mostly for ease of automated manufacture--we will be offering a pre-made board with components already mounted in a few months--but if you're not too afraid of hand soldering intzy-wintzy leads, you may prefer this one, which you can buy here.
Here's the overview of the SMD board:
Here's the component list for the SMD board (Digikey parts): Capacitors:- (C1,C3): 2x 22pf PCC220CNCT-ND
- (C2,C6): 2x 0.1uF PCC1828CT-ND
Diodes:
- (D1)1x 1N4001DICT-ND
- (D2,D3,D4):
- 1x LED (red): 67-1359-1-ND
- 1x LED (green): 67-1357-1-ND
- 1x LED (blue): 160-1643-1-ND
Connector:
- (GPS)1 x EM406 (sparkFun)
ICs:
- (IC1)1 x Atmega168, ATMEGA168-20AI-ND
- (IC2)1 x 74LS157D,296-14884-1-ND
- (IC3)1 x ATTiny45, ATTINY45V-10SU-ND
Crystal:
- (Q1) 1x 16MHZ SparkFun
Resistors:
- (R1,R4) 2x 10kOhms P10.0KCCT-ND
- (R2, R3) 2x 1Kohms P1.00KCCT-ND
- (R5, R6) 2x 220 ohms 311-220ARCT-ND
Switch:
- (S1) Switch SMD, sparkfun
You may notice that the image of the board above appears to be missing some chips that the through-hole version has. That's because they're on the bottom of the board.
Top:
Bottom:
My suggestion is that you repost it as a new discussion topic, which is what it should have been all along.
Like thisThe first op amd is a unity gain buffer. The other two op amps are configured to have 0 -3.3v for an input of 0-1.5v the second op amp would drive an ADC1 input directly. The third op amd
would be biased so that it did not produce output until it reveived an input of 1.5v. This coulkd be easily achieved with two diodes in series to the input of op amp 3 the voltage drop across each would be .7v and two would be 1.4v. A forward bias would be achieved at ~1.4v hence setting the bias. The third op amp would feed ADC2 and readings would only be taken from this if ADC1 achieved an overflow condition (full 1024 bits). This should give more resolution than ever needed. :)
I have the right boards and I have ordered the rest of the parts now.
I will, hopefully, build one or two of the new boards as soon as all the bits get here.
Phil
Good catch! We'd actually been using the right chips, but I put in the wrong link. Now fixed...
Many thanks!
Great work but I have some bad news... The ATMEGA168V-10AU-ND listed in the SMT project is a 10Mhz unit. All the picopower units as designated by the V in the part number are 10Mhz max. You will actually want a ATMEGA168-20AI-ND and it is a 20Mhz unit!
Sorry
-Bill
Sorry about that--I've fixed the link above. We're still improving the boards, so think of this one as a test platform. The final version will be out in Sept (and available pre-soldered)
The link to buy the SMT version of ArduPilot points to the thru hole design. I sure would like to get started on the SMT version. [=)'
1
2
of 2 Next
