Hi, I would like to present my project, i know there are a lot of uav projects but i think it is a amazing balance of price, performance and simplicity! It is based on OLIMEX E2468 board and Sparkfun sensors.Features4 Layer board with ground plane for high noise immunity I/O Connectors:- 8 x Servos - Standard pitch 2.54mm- 4 x speed input (for sensors, motor RPM, or PPM capture)- 2 x CAN BUS with transceivers - Header 2.54mm- 10 x Analog Inputs (8 x 16bit - 5 used for gyros and pressures) general propose 0-5v (for sonar altimeter for example)- 4 x UARTs (one used for USB port) (3.3v level) for GPS and MaxStream XBEE-Pro 60mW radiolinkOnboard sensors options:Accelerometers (two options):- MMA7260Q 6g- analog- LIS3LV02DQ digital 1mg resolutionGyros:- Analog Devices ADXRS300 (any other possible!)- Compass (two options):- HM55B 2 axis 6 bit- PNI Corp's MicroMag 3-Axis MagnetometerOnboard Pressures:- MPXV5010DP 1.45psi (Airspeed)- MPXA4100A6U 15.2PSI (Altitude)Features from Olimex LPC-E2468 development board:- MCU: LPC2468, 16MB SDRAM (more is possible if necessary), 128 MB- Flash, standard JTAG connector for debugging with ARM-JTAG- Ethernet 100MBit- 2x USB hosts- USB-to-RS232 converter device connected to LPC2468 UART- SD/MMC card connector- Dimensions: 90x60mm (3.54 x 2.36")we have make all hardware access rutines in C, included SD card writing and reading with DMA!!!it is a simple micro boards, it is ARM7 so it is easier to program than any 8 bit micros (pic, avr...). Power and memory are enought for the AHRS's Extended Kalman Filter and for another EKF for INS system.this board can run under ulinux!! (we are not using it)It has been designed and build for "UNIVERSITAT POLITECNICA DE VALENCIA", special thanks to DISCA departament.Jose LuisnMine.com
  • I would be interested in a board.
  • Really interesting. I'm studying Industrial Engineering in UPV (although I'm in Finland with an Erasmus Exchange Programme right now) I'll follow this project carefully...
    Greetings!
  • Hi Chris,
    i am working in a MATLAB-FlightGear autopilot simulation, i am getting interesting results!!! i has been very dificult to land in the landing track, but i have no fear now!!!
    http://www.nmine.com/uav/aterrizaje.avi
    i could sell it if i see there are people interested, all boards shown are for university. if there are people interested in project i can arrange it and order assembled boards, it is simple board and it could be cheap.
    That's a beautiful board--many congratulations! Have you written the autopilot code yet?
    And you mentioned a price--is it something you're planning to sell?
