AttoPilot specs
Dean has posted a pdf spec sheet for AttoPilot. Here are the basics: Specifications and Features: Small size: 1.0 ounce control unit 1” x 1” x 1.5”, 2.6 ounces total with GPS and all sensors 6 servos and 6 R/C inputs: 4 flight control + 2 auxiliary servos. Elevon and V-tail mixing are easy to setup. 100% compatible with all 1-2ms pulse 5V and 3V logic R/C receivers, and the newer 2.4GHz R/C systems Flight modes (4): • Autonomous – specific coordinate flight plan, or template plan • Autopilot bypass; remote radio control with Elevon or V-tail mixing • Remote radio control with autopilot stabilization assistance for pitch and roll • Remote radio control with autopilot stabilization for pitch and roll plus navigation; fly by wire Stabilization system: 50 Hz attitude control with automatic control gain scheduling based on airspeed. Elevator gain scheduling for optimal altitude control through turns Onboard data logging: 40+ parameters logged as a comma-delimited .txt file to removable micro-SD media Two-way telemetry: Downlink of 3 nmea GPS sentences plus a proprietary $ATTO nmea message for live moving map in 3D plus virtual cockpit, real time flight plan editing, commanded mission abort, and semi-autonomous flight List of sensors: • Pressure (2): Pitot airspeed and Barometric altitude • 3-axis horizon sensing with dynamic bias correction using other sensors as cross reference • 5Hz GPS with added data smoothing via real time least squares fits • Power sensing: 0-53 Volts, 0-92 Amps, 0-4900 Watts. Energy consumption tracked to 210 Amp hours (Ah) • Auxiliary analog input for user defined function (temperature probe, 2nd voltage or current sensor, etc…) GPS: 5Hz update rate, 10 ft CEP (circular error of probability), DGPS (differential GPS) enabled Waypoints: • 100 user defined waypoints: lat, lon, altitude, airspeed, and multiple trigger options • Lat and Lon to 5th decimal degrees (3 ft) and 3 ft for altitude • Return-to-home position: defaults to start location or specify at a remote location • Create waypoint paths graphically with point and click ease on your PC, with or without internet connection • Waypoint file optionally may be marked as a template. AttoPilot remaps a template path to current location upon GPS lock at power up. Useful for photo mapping grid at various flight locations without a laptop PC in the field. A big saving of pre-flight setup time for multiple repeated missions in various locales. Triggers: • RTL (return to launch) based on low pack voltage, mAh consumption, or maximum time allotment • Loiter at waypoints, specify circle radius, altitude, direction, and duration • Auxiliary servo or logic controls at specified waypoints or between waypoints with time or distance intervals • Distance interval triggers are perfect for grid photo mapping Barometric altitude: Estimation to 0.3 ft and real world control to +/- 6 ft. Barometric climb rate estimated to 0.3 ft/s Maximum Limits: • Distance per waypoint leg: unlimited • Flight plan total distance: unlimited • Turn rate: 120 deg/s • Pitch and roll rate: 300 deg/s • Pitch angle: 60 deg • Roll angle: 60 deg • Altitude: 30,000 ft barometric and 60,000 ft GPS • Airspeed: 125 mph via Pitot tube • Speed: Above 125 mph, GPS speed is used
  • January (depending on cables arriving and plastic cases done at injection molder). Although Atto does a heck of a lot more than the Picopilot NAT (in fact it exceeds the U3500FW but with price savings of thermopiles), I decided to start Atto v1.8 at $800 to go head-to-head with the Pico-NAT.
  • Following this one for a while :)
    Any ideas when it will be avalible and what we can expect to pay????
    (going to be used on a moddified 4.0m motor glider with gimbal...... I Hope ;)
    Cheers
    Jamie
  • The digital values are there, but video resolution was too poor to show it. I also think they number boxes should be about 2X the size. I did more flights this morning with 2x the video resolution, and will post a 14th video on RCGroups on the same page
  • Ground Control demo video of AttoPilot just posted on RCGroups, link here: http://www.rcgroups.com/forums/showatt.php?attachmentid=2166899
    This is just display of some downlinked parameters, not uplink control of plane (coming soon). Check it out!
    RC Groups
  • Michael,
    MicroGCS still will not run on W2K.
    Jim
  • Michael, I lost the link you sent for MicroGS... I can't even seem to find it here. Anyway, I have the telemetry downlink data you asked about. Today I did a 20 minute flight with system on the ground logging telemetry downlink byte stream to micro-SD card. I can give it to you as a "TEL.txt" file, or send you a simpe hardware item and micro-SD that replays the data into a USB COM port as if it were a live downlink. Should be very useful for testing a live virtual cockpit once you get the parsing setup.
    Oops, now I see it is MicroGCS, not microGS.. will try again
  • when this product sell ?
    I don't know if he monitors this site as often as that, but you could try http://www.attopilot.com/
    Attopilot.com
    Shouldn't you be asking Dean about this?
    Chris is relaying the Atto news.
    Attopilot.com
