9x gets 3DR 915 MHz air module
Finally completed the 3dr mod on my 9x. Seems to link up instantly - no more waiting for mission planner to download parameters or the awkwardness of forwarding the mav data back out over bluetooth!
3689527510?profile=original
3689527447?profile=original
3689527573?profile=original
More details, as requested:
The stock 9x has the Throttle Cut and Aileron switches connected to a UART on the Atmega. These need to be re-routed to free up the UART for telemetry purposes. There are several posts out there on how to do it - this was the cleanest (from https://code.google.com/p/open9x/downloads/detail?name=9x_modifications_EN.pdf):
3689527092?profile=original
Since I have a smartieparts 9x programmer, I didn't have to worry about the connections going to the header on the left - just the two connections that are circled in red.I reused the resistors that came off the pads (Thanks to Rod for his fine soldering skills). Note that the connections are made from the bottom most resistor pads up to the resistors then they cross over and attach to the two free pads on the right. Keep in mind that once this mode is made, firmware is required that knows about the new locations.
After that, I installed the smartieparts programmer according to their installation instructions:
http://www.smartieparts.com/shop/index.php?main_page=page&id=9
With that in place, the extra UART is now availible on the TelemeterEZ port (two pin header, top row, left):
The 3dr air module conveniently runs at 5v, so I grabbed 5v and ground off the back PCB (you can just barely see the connections in the 2nd photo from the top above). 5v is in the middle, ground on either side of it.
3689527539?profile=original
When installing, I connected power and ground to the 3dr module first (red and black wires on the cable that came with it). Fired up mission planner and when through the radio setup to load the correct settings into the module. Then I unplugged the usb radio for the PC (to make sure it didn't interfere) and powered up my quad - data stated flowing to the module in the 9x. This made it easy to identify which way to hook up the RX/TX lines to the TelemetryEZ port on the 9x Programmer board using my DSO Quad pocket scope.
Next time I open up the 9x, I'll grab photos of the actual connections. The OpenTx developers are currently working on adding Mavlink support - I was a little impatient and rolled my own, but I do intend on getting my code to them so they can merge all the best ideas.
I should also add that I'm not 100% sure the radio module won't draw too much power... it probably makes sense to at least add a cap between the power and ground connections to help the regulator out.
  • Great work.. I will give it a try. Are you going to work on options for planes too or are you going to focus it more on copters?
    Thanks,
    Great work. I wish I had programing skills like you.
  • Wow, great! Thanks for sharing, Bob.
  • As promised, here's a link to my OpenTx build:
    https://dl.dropboxusercontent.com/u/80997643/DiyDrones/DiyDrones-Op...
    You get at the info screens by long-pressing the DN button and then you can cycle between them with the UP/DN buttons. Get back to the main screen with the EXIT button.
    Here's what they look like now. For the 1st screen, I just added altitude and climb rate over on the left. The stars at the top are indicators that particular messages are arriving. Battery info on top, distance from and direction to home bottom left, satellite info bottom right.
    3692733670?profile=original
    The 2nd screen has Roll/Pitch/Throttle/Yaw stick information under "In" and the controllers mangling of those under "Out". For the motor information, I averaged all 4 motors and put that number in the middle (%), then for each of the motors I put their percentage of the average to normalize them (so below you see 49% total average, front left running at 1.15 x 49% or 56%).
    3692733486?profile=original
    The caveats are (mentioned above in a previous comment, but I'll do it again)
     - Battery warning beeps are hard coded to 10.2v and 20%. (3s battery)
     - The 2nd screen assumes you have tweaked the 9x offsets and endpoints such that the ArduCopter code sees 1000-2000us, mid at 1500 (I convert to percentages assuming that range, don't forget to re-calibrate your ESCs if you do the same)
     - The code assumes motors are arranged [1 = FR, 2 = BR, 3 = BL, 4 = FL]. It is unlikely this matches your copter because I wrote my own mix table specific to my V-Tail.
    If you want to change any of these - you'll need to modify the source and rebuild (some info in the README.txt file about this).
    I have been flying this with no problems, but as with all open source - no warranty or guarantee  ;)
  • @Bob
    Thanks for the confirmation.
  • Yes. I'm not currently sending anything with air module in the 9x, but data is definitely flowing from the air module in the copter to my 9x.
  • Good stuff.  I haven't tried it yet but, if I had two 915MHz Air modules, would they be able to communicate both ways?  It seems this works out of the box (by what is described above) but just wanted a sanity check before making an investment.  Thanks.
  • Also here: http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=...
    http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=815&productname=
  • I believe HK has a knock-off of this for $29.99 (USD) found here: http://www.hobbyking.com/hobbyking/store/__22315__FPV_Radio_Telemet...
  • Did some flying tonight and didn't notice any problems with the control - seems like a successful mod!
    Joseph - I may not get a chance to post any code tonight. Duties call, but I'll get to it soon.
  • What are you looking for? A source patch or a compiled hex file? My hex has the following options built in:
     - Ardupilot 10.2V voltage warning, 20% remaining warning (may be eeprom options someday, but not today)
     - SP22 (inverted) PWM_BACKLIGHT support (backlight driven through the smartie 2.4 programmer board)
    The 2nd menu (not shown) is even more specific. It shows stick positions in percent as seen by the arducopter code, and assumes that your 9x offsets/endpoints have been adjusted so that arducopter sees 1000-2000us, mid at 1500 (don't forget to re-calibrate your ESCs after changing). It also shows the copter's modified values for the sticks along with the average throttle % for 4 motors and % offset from average arranged in the order of my motors (1 = FR, 2 = BR, 3 = BL, 4 = FL).
    I'll try and put up a source patch and my hex on dropbox later tonight. Perhaps a blog about how to set up windows to build OpenTx from source too?
