A small modification to the AP Mount Library Code
3689506756?profile=original
 Hi, I have made a small modification to the "AP_Mount" library to be used mainly by the filmmakers, basically is:
1- Add a dead zone when we use the joystick mode to prevent undesired movements of cam, you can change the dead zone using the min and max value in ms.
#define CAM_STICK_DEAD_ZONE_MIN 1400 // Set the dead zone in ms
#define CAM_STICK_DEAD_ZONE_MAX 1600 // Added by Pablo Zeron
and disable this mode with:
#define SLOW_STOP 1 // 1 -> Enable the slow stop 0 -> Disable
2- Add a slow stop mode, until now when you release the stick the movement stops, but with this option the movement continues in base at the actual speed and it goes down slowly trying to get a smooth motion. The stop speed can be change by this parameter:
#define SLOW_STOP_SPEED 0.02f // Change this value to make it faster or slower.
I am a beginner programmer, and I hope that Amilcar Lucas or Gregory Fletcher can take a look to the code and check if it is well done or can be optimized, but it works well for me.
Thanks.
The files:
AP_Mount.cpp
AP_Mount.h
