ArduCopter Loiter Tuner / SIM
3689457389?profile=original
This is a simulation I'm working on to improve the Loiter control laws and discover optimal gains. I have identical code from Arducopter running in Flash as OO Javascript so I can ensure the behavior is the same as the real thing. I tested the MTEK GPS to find the actual latency and accuracy and then modeled it in code. This allows me to test PIDs and other coding ideas to see how the copter will behave in real life. The copter itself is a simple physics equation and should be fairly accurate. To better tune the SIM, I can compare AC Flash Logs from real flights side-by-side with the SIM flights which also output the same text based logs.
I've already found many areas for improvement in the Loiter code which i've just checked in to the GIT repository.
Hopefully this tool will serve as a great PID introduction as well. I know I've learned a lot by comparing plots with small changes in the gains.
Jason
    This is so out of date it won't help you. The original was lost when the wiki transitioned.
    Sorry,
    Jason
    try jasonshort.com
    This is pretty outdated and probably broke when the Wiki was switched over.
    Jason
    ArduCopter SIM
    Gusts are in the next version now in development. They are pseudo random and repeatable gusts so you can plot two flights against each other knowing you have identical conditions. Give me till the weekend...
    Jason
  • Awesome job!
  • That is realy awesome. On version 1 have literally sit hours changing the values and just seeing what does the graph do to get use to what the variables mean and how to manipulate them to get the response I want.
    It's also really, really fun to use. did you check out the Flip in Acro mode video? That's the SIM running an automated flip using the CH7 toggle.
    http://diydrones.com/video/sim?xg_source=activity
    Jason
  • I agree 100%, the sim is not just sweet, it is mind blowing, and because of this alot of people save alot of money on blades and parts because of this.
    I'm asking because I'm developing a very sweet SIM and it's quite an effort. It will have all of the AC params and some hardware details like Kv and weight. I'll probably post more in a week.
    Jason
  • I recon what made this product sooo successful is that there is not just the hardware but there is software supporting the product as well and as a software developer I know that no piece of software will ever become grate if there is no criticism and external inputs.
    Here's a question. If you could have a SIM that had all of these factors and could simulate virtually all of AC flight (but 2d Only) what would it be worth? Would you donate towards its development?
    Jason
