We have been working to develop a well oiled solution for Aerial Survey and Photogrammetry over the last few moths. While there are a number of off the shelf solutions out there which produce great results, we are looking for something that will cover larger areas at a higher resolution. We started with the X5 as it could be hand launched and was a good platform that flew at higher airspeeds and could progress us into the X7. Here is some of our progress;
The X5 is running on APM 2.6 and has prove extremely reliable and stable. The camera used is a canon IXUS 132 running CHDK and shooting on an intervalometer script. The main purpose of the X5 was to learn about vibration dampenning and apature and ISO settigs to produce clear images. This took a significant amount of effort, however we are at the stage where 2 out of 3 images are photogrammetry quailty.
Our test baby has had a few hard landings (things were laid out a little neater when we started) . We are very excited about the recent interest and work being done on laser altimetry in recent months. We are also currently testing one of these devices as flying wings are extremely hard to land manually (especially when they are loaded up with gear). You can see the APM in the middle of the plane, 5.8GHz live video and 900MHz telemetry transmitters, and the IXUS 132.
We found the X5 reasonably easy to hand launch WITH A WELDING GLOVE (it will cut your hand to shreds - not if...when). You can see the camera poking out of the front of the plane. Images are good, however, to get the plane to navigate the survey grid well, it becomes a little twitchy which means that a high number of the images are not taken pointing straight down. Navigation accuracy (Nav Constants and Pitch and Roll constants) v's image quality is a trade off. Others may have found the perfect solution..we haven't. (Yes we are investigating some of those gimbals). We found the ideal cruise speed with a 4S 5000mAh battery was about 12m/s and we are getting about 30 mins of flight time.
We have been using Agisoft Photoscan which works really well and appears to be more flexible than Pix4U. We have no surveyed ground control in the images, and we have no geotags in the photos as we were running an intervalometer script. However, it was great practice flying and processing, changing settings and trying again. You cans see that you lose images when the camera is not pointing down and loose some of the survey area. We have found that it is better to not use bad images and have gaps, rather than use them and distort the good data.
Once we had some confidence in what we were doing, we unleashed the BEAST!
First of all, the X7 is more streamlined than the X8, but doesn't have anywhere near the same room for hardware. If we were to do another flying wing, we would try the X8. We are running the X7 on Pixhawk and have a nikon J2 taking photos. The J2 is triggered from the Pixhawk via an infrared LED shutter controller.
The Nikon is snug in expanding foam with its lens fitting nicely into the camera hole in the X7. With decent batteries and a big camera, you simply can't launch the X7 by hand, so we have built our own heavy duty catapult powered by 4 spear gun rubbers;
It took a while to settle down the nav and flight constants for the X7 but it flies beautifully once tuned. It cruises at around 15m/s and is far less twitchy than the X5. Photos are higher resolution and a lot sharper. We love it as an aerial photogrammetry platform, however landing is still an issue. As well, as we are only running 4s batteries, it's always touch and go as it comes off the end of the catapult. We are still playing with battery/motor/prop combos to get the optimised take off and duration.
Again, using Agisoft Photoscan, (with Geotags, but no ground control), the results were extremely pleasing;
We are still playing and tuning, but our focus at the moment is;
1) ground control -we are looking at a network gps system where you can drop a bunch of transceivers around the survey area and have them log back to a central PC where only one of the transceivers is located in a surveyed location.
2) AUTO LANDING....WOULDN'T IT BE NICE !
3) We have purchased a 757 Ranger to try slower speeds, but significantly longer endurance to see if it improves the sharpness of the images.
Anyway, this is what we are up to. Would love to hear comments from anyone else out there chasing photogrammetry.
@Simon, I know that Tridge adjusts the altitude during his OBC (outback challenge) runs which last 30+ minutes. There is definitely a parameter that allows you to adjust the pressure in flight. I'm not sure if it can be done automatically though by attaching another baro to the ground station.
On a side note, I saw the 3DR Aero perform a 20min mapping mission in Berkley CA last week after I attended AVC & Dronecon. It was a thing of beauty watching it crab through the air (crosswind of 10m/s) during it's mission. It's autolanding landed short by about 15m perhaps because of baro drift (I'm not sure if that was the cause, it was also landing uphill which would tend to make it land short i think).
ALK - brilliant! We struggle to use the telemetry logs to geotag the images as if the camera fails to fire for one or two it throws the whole timing out. How do you work out if the camera has fired on every command?
Good job!
Here is our example, with a Skywalker + Pixhawk and Canon SX260
The job was to get 1100 ha to verify some farms for illegal occupation of a protectet conservation area.
- 2 flights total area of 580ha - 35 minutes each flight (limitation is the limited number of waypoints, something that MUST be fixed)
- 1096 pictures (mission planner distance camera shutter)
- Used telemetry logs to geotag pictures and also GCPs
- Agisoft to process everything and Globalmapper for some good DEM.
- The full resolution stiched image is 51000 x 44000 pixels - over 2 gpixels
Early version in Gigapan (its not the full area, we had to split it in chunks and then merge the chunks)
http://www.gigapan.com/gigapans/7658f6d35b3ca1fc290748ba67340d98
NIRGB Modified Canon Camera Camera from EVENT38 - Not processed to NDVI yet. (used this camera for only a small area, 70ha of the 1100ha)
Sample below: (low res)
The 580 ha area in low resolution of course:
zheng - you need to make sure that you set the distance between photos to be big enough to allow the camera to take the photo. i.e., if you are travelling at 15m/s you need to allow 20 metres between the photos with no auto focus and a high speed memory card.
eko - the battery for the x5 is strapped under the cover
jeremy - thank you for your support
dave - what speed are you landing at?
cedivad: GPS altitude error is +-30m. It's used in flight, but it's not accurate enough for landing.
Can't the APM automatically correct it's barometric height using the one provided by the GPS? You should obtain a pretty accurate reading.
Ausdroid, where do you put battery on x5? I saw no room for battery on your picture?
After Trent's USA trip bad experience with hard landings, and this testimonial, plus many other confirming auto landings do not function reliably, I hope a SF02 laser solution will be soon available and cheap enough.
We need to fly wings in small landing spaces and parachutes are not a good solution.
Simon,
Good Question. We have also wondered about this. I guess you would have to calibrate the ground unit against the air unit. However, the laser altimeters will be brilliant once they are sorted out.
Martin,
Yes it's above the motor, but it's on a 6 inch mast.
1
2
3
of 3 Next
