This new Indiegogo project looks very good, and at $225 Reach is about a quarter of the price of other RTK GPSs. Backed!
What is Reach and what is it for?
Reach is for applications when your standard GPS with several meters accuracy just won’t cut it. It relies on RTK (real-time kinematics) technology to deliver centimeter level accuracy.
RTK was here for a long time, used mostly by surveyors and unaffordable to hobbyists and makers. If you needed centimeter precise positioning you had to spend thousands of dollars on an RTK system. With Reach we want to change that.
Reach runs open-source RTK processing software called RTKLIB written by Tomoji Takasu. Previously a computer was required to run RTKLIB, but now all RTKLIB features are available directly on Reach.
Antennas matter
High quality antennas are the key to great RTK performance. Tallysman Wireless, an industry leading company in high accuracy antennas provided their latest advanced antennas for the project. These antennas receive Glonass G1, Beidou B1, GPS L1 and Galileo E1 signals as well as signals from corrections services.
“The Emlid Reach program is an excellent example of the potential for huge reductions in cost available of precision RTK positioning systems. Tallysman’s Accutenna™ technology is a great match for the Reach product because it too provides high precision at new price levels.  Just as one wouldn’t expect a high quality image from an expensive TV receiver with a “rabbit ear” antenna, one should not expect the levels of precision the Reach product is capable of with a low precision antenna. Tallysman’s raison d’etre is production of high quality, high precision antennas at an affordable price for systems exactly such as the Emlid Reach product.”
20150501061938-Allen_Crawford.jpg?1430486378
Allen Crawford
Director Marketing & Sales, Antennas and RF Products, Tallysman Wireless
Examples
Static mode
20150430042747-Reach_Static_comparison.png?1430393267
Kinematic mode
20150430042803-Reach_Kinematic_comparison.png?1430393283
Possible applications
20150430045516-Tractor.jpg?1430394916
GPS replacement for your drone
We are experienced with APM autopilot and are working on integration with Pixhawk and other APM based autopilots. Reach can be powered from autopilot port and will send accurate coordinates using NMEA protocol.
Entry-level survey receiver
Participating in OpenStreetMap project? Planning your yard? Use Reach to survey points and mark them within the app.
Tracker for racing, cycling and other activities
Record your precise tracks and then export them in Google Earth format.
Your own RTK base station
Set your own base station on the roof of your home or club house and share corrections to others. One Reach unit set up as a base can provide corrections to a virtually unlimited number of rovers.
How does it work
To achieve centimeter level accuracy two GPS units are used with one of them being stationary (base) and another one moving (rover). Base unit streams correction to the rover over radio or 3G.
It’s simple - all you need is to setup Reach to receive corrections from a base station:
1) Use a pair of Reach modules connected by radio modem, wi-fi or over the internet. One would act as a rover, while the other one would be your own base station.
20150430044040-Reach-and-Reach.png?1430394040
2) Or use WiFi to connect to your phone or plug 3G USB modem to receive corrections over the internet from an NTRIP base stations available in your area.
20150430044053-Reach-and-Internet.png?1430394053
Features
Multi-constellation
Reach is able to use not just GPS, but also Glonass, Beidou and QZSS which significantly increases amount of visible satellites resulting in a faster and better solution. Reach also uses signals from differential corrections systems SBAS, EGNOS, GAGAN. A future firmware upgrade will bring Galileo support as well.
IMU
Reach is equipped with a 9DOF inertial measurement unit that allows us to determine not only position, but orientation as well. By fusing IMU in RTK processing software phase tracking algorithms can be improved to work better.
App
We are developing an app called ReachView to make Reach user-friendly. Simply connect to device over Wi-Fi and you can tweak the setups, monitor solution status or view the satellite reception quality. Works on any desktop or mobile.
Connectivity
Reach is an internet of things device, it has a tiny yet very powerful Linux computer inside with Wi-Fi, BT and USB OTG port for cellular modems. You can even tether internet from your mobile device. That means that whatever setup you have it will be easy to stream corrections from the base to the rover.
Accurate time-mark
For high precision geo-tagging Reach is capable of capturing a time-mark with 21nS accuracy, you just need to connect it to a sync pulse source from your device. Time-marks are stored in memory and then can be used to determine position at a certain moment.
External antenna
High quality antenna is the key to RTK performance. Depending on your application you might want to connect different antennas, lightweight one for airborne applications or a large, heavy one for the base station.
Specs
20150501060652-Reach_TopAndBottom.jpg?1430485612
Raw data receiverU-blox NEO-M8T - 72 channels, output rate up to 18Hz, supports GPS/QZSS L1 C/A, GLONASS L10F, BeiDou B1,
SBAS L1 C/A: WAAS, EGNOS, MSAS ,
Galileo-ready E1B/C
Processing unitIntel Edison - dual-core 500MHz
ConnectivityI2C, UART, GPIO, TimeStamp, OTG USB, Bluetooth, Wi-Fi GNSSAntenna connectorexternal with MCX connector
Very compact: 25x35mm
Lightweight20gr
Antenna: Tallysman TW4721 Dual Feed GPS/BeiDou/Galileo/GLONASS
Risks and Challenges
Our team has years of experience in electronics development and production. We know every step needed to be taken from an idea to shipping ready to use devices. Maximum risk is a production \ shipment delay due to an unexpected lack of components stock.
This is also not our first Indiegogo campaign. We have successfully delivered all perks for Navio campaign, launched second generation called Navio+ and delivered full software support.
FAQ
How accurate the coordinates of Reach are?
If you have a base station with known coordinates and a good antenna, you can expect accuracy down to 2cm.
Is it 100% reliable? Will I always get cm coordinates?
No RTK receiver will provide fixed solution all the time. RTK requires good GPS reception, high quality antenna and low EMI. Bad weather conditions might also degrade solution quality.
Why is it so cheap?
We rely on open-source software and off-the-shelf electronic components. This lets us push the price so low.
What is the max range?
Recommended maximum range from the base station is 10km.
How ready is it?
All RTK features work and hardware prototypes are fully tested. We are now developing an app to make configuration easier.
What is the output format?
Solution is output in NMEA format, logging is done in Rinex.
Why does it say NEO-M8T in specs and on video it is NEO-6T?
That’s an early prototype shown in the video. All final boards will have NEO-M8T.
  • Reach Documentation http://docs.emlid.com/reach/
    Thanks Daniel, good to know that you received your kit,
    Please let us know when you have anymore info on the Pixhawk integration
    once its reelased on their website
  • Just received my Reach kit in the mail. Nice to see that they took the time to get nice packaging made up for the devices. The devices are much smaller and lighter than I expected. I have not touched or configured them yet. I am going to wait until the weekend to start checking them out. I am just glad they are here. I was waiting for these so I could begin work on a Pixhawk rover project, however according to Emlids website the Pixhawk integration is not complete. I do not know enough about how these operate to say I could get it to work in their current state of development. I am hopeful that the integration portion will happen much sooner than later. I still think there is a big learning curve here so perhaps by the time I get familiar with this new gear the integration will be complete!3702135474?profile=original
  • Good news -- they will be shipping already according to there
    http://www.emlid.com/blog/
    Just a quick update from the factory. We have some exciting news to share: all the Reach modules have been produced. Currently, the devices are being flashed and tested at the factory.
    reaches
  • can anybody provide a guide or training about how to integrate RTK functionality to Pixhawk that really works? Hopefully with Reach but other modules are welcome.
    Willing to pay for this training/tutorial. Willing to travel also.
    Please PM me.
  • Is there any recent update ?
    It was suppose to be shipped by July & its almost over. Eagerly waiting :)
  • Is this out for sale?
  • Thanks Igor, have "backed" for a full set on Indiegogo
    I'm not sure how much the team has been involved with RTK surveying, but just for reference:
    re
    Q  " 2)        With our existing terrestrial RTK kit, on the base we can collect an autonomous position for say 10-20 minutes and then use that for the nominal base location, and then collect RINEX at the base station during the survey, and on return home post-process the base’s RINEX and then use that to adjust all co-ordinates acquired by the rover.
    Can we do the same with the “Reach” base station?
    (and in case you’re wondering, the reason we’re looking to consider “Reach” for base as well as UAV rover, is that although our Ashtech kit is dual-frequency L1/L2, it is older GPS-only so no Glonass, Galileo etc.)."
    A:  "2) Yes you can, but your rover position will be only as precise as base nominal location."
    I might not have made it clear. If we collect/use a nominal position, we know our actual flight path will only be as accurate at the time of flying as that nominal position, and all camera trigger positions will be consistent but equally displaced by any error in that nominal position . However, if we can collect RINEX from that base station whilst the campaign/mission is being flown, we can then post-process that RINEX (using exact emphemeris as well) to get a more accurate position and then perform what surveyors refer to as "an adjustment" and shift all positions (each camera point etc.) by say x+0.37m y-0.41m z+0.715m thus giving us more accurate camera positions.
    Key to doing this is (i) that the program to operate the base station allows the base receiver/controller to collect autonomous positions and average them for a period until the users says that is good enough, (ii) the base then uses that averaged position as the base position, and (iii) the base continues to collect RINEX throughout the campaign/mission so it can be post-processed to get a more precise position (which we can then use to correct the camera positions).
    Dave
  • @ Dave Martin
    Thank you for pointing us here.
    1) In the emmc memory, possible to download over USB, network or ReachView app.
    3) Yes.
    4) They will be logged in the separate file at the moment, but we will implement Rinex event logging in RTKLIB.
    5) We are getting TW4721 custom made for our backer, they will come with adhesive mount instead of magnet.
    6) Currently there is no solution to this except for a separate power source, but this is a very good point, we will see what is possible to do here.
    7) PIxhawk restart will not cause solution reinitialization.
  • Wow, it's half the price of SwiftNav Piksi && it's Open Source && most importantly it WORKS! unlike Piksi after 1+ yrs of delayed support for the most common FMU.
  • Igor,
     I’m very interested in the “Reach” RTK GPS for our UAV platform (Pixhawk controlled) we’re using/developing for archaeological photogrammetry.  Could you advise on a couple of points please:
     1)        How/where is the RINEX stored?
    3)      Can the rover log RINEX at the same time it is emitting the NMEA sentences to the Pixhawk?
    4)      How and where are the time-mark (in our case, camera shutter) events logged? And can “Reach” log a position at that same instant?
    5)      The packages on Indiegogo specify two Tallysman TW4721 mag-mount antennae will be supplied. Mag mount would be OK for putting on a ground plane for the base, but wouldn’t want to put anything with a strong magnet in on the UAV – are you able to offer a non-mag-mount antenna for the rover?
    6)      For UAV we change the battery possibly a number of times during one survey ‘mission’. We don’t particularly want to have to fly another extra battery just to power the “Reach” – but equally we definitely don’t want to have to wait for integer ambiguities to be resolved again every time we change the UAV battery.  I see there’s a “hot-start” super-cap but is that enough to keep the full solution running? Presumably we’d have to keep the RTCM link receiver powered as well …. Are we just looking at an external power management to cover ‘brown out’ whilst changing flight battery?   Do you have anything special planned to cover this situation?
    7)      If the Pixhawk is reset (on the ground!) whilst we are trying to keep the RTK solution live, will a Pixhawk restart cause the Reach to reset or re-initialise the solution from scratch?
    Thanks in advance / Dave
