Allegro acs756 current sensor for arducopter
allegro current sensor
allegro.jpg?height=297&width=400
allegro2.jpg?height=254&width=400
The sensor is galvanically isolated from the circuit, but in contrast to the classical current sensor shows not only the battery discharge and charge it (eg energy recovery in airplanes)
but because of this, at zero current output, exactly half the supply voltage (for classical sensors autopilot 0) ie 2.5 volts.
to correct this misunderstanding to change firmware code
defines.h  change
#define CURRENT_AMPS(x) ((x*(g.input_voltage/1024.0))-g.curr_amps_offset)*g.curr_amp_per_volt
parameters.pde add
    // @Param: AMP_OFFSET
    // @DisplayName: current sensor zero calibration
    // @Description: in volts
    GSCALAR(curr_amps_offset,      "AMP_OFFSET", CURR_AMPS_OFFSET),
parameters.h  add
      k_param_curr_amps_offset = 193,
      AP_Float        curr_amps_offset;
//#ifndef CURR_AMPS_OFFSET
 # define CURR_AMPS_OFFSET               0.0
//#endif
allegro4.jpg?height=400&width=340
archive with source and HEX file for quaid "x"  APM2 here
  • many thanks Andrew,
    unit of measurement offset in volts, the range of values ​​from 0.00 to 5.00
    by the way this applies to standard sensors to calibrate the zero value
    Thanks Alexey! I've added your change in for the next release.
  •  dont calculate cf and rf
    it may be
    rf =  1KOm - 3 KOm
    cf =  1 - 4.7  microfarads
    rfcf filter needed for accuracy measurement  of "average current"
  • Alexey,
    Awesome job on the voltage regulator!
    So did you build as in the schematic posted above and if so, what did you use for Cf and Rf ?
    Rick
  • new value amp_offset  used for tune input voltage on current sensor port "a1" with "zero current" allegro sensor with "zero current" have about  2,5 volts output
    amp_per_volt  used too, for calibrate sensivity
    for +-100A allegro chip it is 40.0
    for +-50A allegro chip it is 20.0
  • so the only vlaue that we have to determine is the "g.curr_amp_per_volt" am I right?
    im tested with apm2  connect all 3 pinsto port a1
    Gnd-gnd
    +5 to +5
    vout to signal
  • Just to clarify the Ears are soldered to the + leg of the connectors with the - leg straight through.  And looking at the label side,  it is wired + - S for the connection to that APM?
  • Allegro current sensors are great! I started using them in my final year engineering undergraduate project, and haven't turned back since. They're affordable, and just as accurate as current transducers more than ten times their cost.  (An RC filter on the output is useful)
