Hello all,
I am working on a VTOL concept and thought I would post it here. I hope to get as much feedback as possible from anyone who has any. The depicted airframe is the simplest embodiment that would be capable of both rotary and fixed wing flight. Alternative versions could look very much like a conventional helicopter having a stationary fuselage and a very small tail rotor or control surface. This is basically just my website copied and pasted. This is a concept only at this point, no prototype. Also, the ducted fans were just for simplicity for the animation, not necessarily for the working aircraft.
Thanks for looking.
- Joe
- Joe
What about payloads? It is quite hard to distribute payload equally near the center of mass. Having it not equally distributed should cause massive vibrations in hover mode.
On a more helpful note, you need to work on pitch control. tilting your wings is not an effective method of pitch control.
the term "electric ducted fan" is not allowed to be used with the terms "efficient" or "not that loud" or "these make a lot of sense, lets use them"
It's a very interesting idea. First issue I see is that you probably can't rely on differential thrust alone. At least you are going to have to increase the moment arm of those motors.
I once saw a flying wing design that shifted the propeller to the wingtip so it became a monocopter and then landed in that configuration.
Tailless with rotary wing. :)) 1-th place !
1
2
3
of 3 Next
