3689573949?profile=original
The ETH video demonstrating a new algorithm to save a quadcopter after a single motor or prop failure didn’t reveal the algorithm. It did get me thinking about the quadcopter dynamics after a motor or prop failure.  My analysis starts with the model above, and the equations in “Quadrotor Dynamics and Control” by Randal W. Beard, Brigham Young University, February 19, 2008, available at
http://image.ednchina.com/GROUP/uploadfile/201304/20130429210226589.pdf
The PDF attachment to this blog post shows why spinning up the body axis yaw rate after a motor or prop failure helps with quadcopter controllability, and points to potential new control laws that use controlled body axis yaw rate to allow cross-coupling between pitch and roll control.  My next step is to try to work out a specific, simple motor or prop loss recovery algorithm. I haven't taken it that far yet, but there are a lot of sharp, creative and inventive people in this community. If it looks like this is on the right track, let's see what we can do with it.
I wrote up the analysis in Word 2010 and its useful equation editor. I then discovered that it's not easy to copy and paste those results into my blog! I looked at converting everything over to JPEGs to paste it up as images, but the resolutions on some of the equations suffered. The best way to share the results is  to convert it to a PDF document, the attached file.  I look forward to your peer review - maybe I made a mistake or overlooked something.
Blog%20Quad%20John%20Malley%20%20February%209%202014%20Post%20on%20Spinning%20Quads.pdf
John
  • @André Bertelsen - Thanks for pointing me to L1-AC and the on-line lectures. Google shows there's activity in applying it to quadrotors as well as fixed-wing UAVs.  I read two papers this weekend with strikingly different takes on L1-AC The first is from Buddy Michini and Jonathan P. How at MIT in the USA,  http://acl.mit.edu/papers/L1GNC09.pdf . The second is a critique of L1-AC by Saeid J. Jafari, Petros A Ioannou and Lael Rudd, at http://arc.aiaa.org/doi/abs/10.2514/6.2013-4513  No matter what, they would agree that Model Referenced Adaptive Control approaches might work wherever L1-AC can be applied.
  • @ArthurK - Still thinking about your suggestion.
  • Looks good, you should look into L1 adaptive control - a good lectur about it here:
    https://www.youtube.com/watch?v=w8L2JdmpccE
    I'm currently making my masters about an L1 controller on a quadcopter - hoping to make it run on the APM (dont know if there is enought CPU)
  • Off the top of my head, I don't know. We would want to look at the moments of inertia for the tricopter and the body axis attitude accelerations in terms of the cross-products of pitch and roll rates when the tricopter has a body-axis yaw rate.
  • Yes!
    Thats great news.
  • Well done.
