Android based GCS with Bluetooth <-> XBee bridge
img20110426235731.jpg?width=600Hello all,
When I started with my copter, I thought of making a Linux based GCS, as I don't run Windows. However, I decided that trying to duplicate all the work on the Windows GCS was counter productive. On top of that, my laptop is dying, so in the field it would be less than useful anyway.
I recently got an Android phone, in part for its programmability. Linking it up to a quad (or hexa etc.) seemed like it would be useful. Therefore, I've been working on an Android based GCS, and although by no means done, I thought I would share and maybe get some feedback on desired features.
The phone really only has WIFI and Bluetooth for connectivity, and my quad has neither of those as options. Finding a 802.11 link for on the quad proved tough, and the range on Bluetooth is not good enough for what I am looking for. To solve that I made a Bluetooth <-> XBee link: its small and just stays in my gear case while letting me use the phone at long range from the quad. When using my laptop, I can just use it's bluetooth connection and still use the standard configurator.
I needed a place for code, so if interested, its hosted at Copter-GCS Wiki. There are screenshots there showing features, but in a nutshell:
-Configure PIDs
-Calibrate Offsets and Transmitter
-Sensor graph for current outputs
-Map the quad GPS position, as well as the phone's
3689404856?profile=original
readouts2.png?width=400
Like I said, its not done, and has some things to work out. Once I do I will make the code available (if there is interest). There are a bunch of things I want to try with this, like GPS following etc, but this seemed useful for in the field calibration/testing. When Arducopter 2.0 comes out, I will update so that the MAVLink protocol is compatible.
Cheers,
Bart
  • 57600, not sure about the timeout on the xbee, whatever is the default I suppose.
  • For those of you interested, I've released a new version with MAVLink support and a HUD. Because of MAVLink, you can now also use if for your planes.
    New post at http://diydrones.com/profiles/blogs/coptergcs-now-supports-mavlink
    Cheers,
    Bart
  • @Frank
    You mention the planner, so am I correct in assuming that you are attempting to use MAVLink (AC2)? The current version doesn't have mavlink support yet, just AC1, I should be able to release that on the weekend.
    The app doesn't care about or set any baud rate, so that should be fine.
    There is a bug in the current version where the wrong protocol would crash the app after receiving 1000 bytes.
    If my assumption is wrong, let me know and we'll figure out what's going on.
    Cheers,
    Bart.
  • hey bart find me on the chat, I treid but you don't replay, in the main blog there are instruction on how to
  • If you already have the sdk, and are comfortable, then just get the googlemaps api key, download the code from the SVN, and compile, as its not very hard. However, I figure not everyone is at that stage, and for that reason it seems the Market may be a simpler way to go.
    Baud rate is selectable, but it depends on which code you are running. For me, on the ardupirate version, its a compile flag. I'm not sure about other versions. Check out http://ardupirates.net/config as a start, or look into the config files.
  • so is the telemetry baud rate of apm selectable? I found no instructions on that. frsky protocol is a pain but I have the subroutine for arduino already working without problems so..
  • @bart
    what is the problem in publicly give the apk? I have the sdk installed for debug purposes, is it difficult to compile the apk by myself? I'm interested in your opinion about apk publishing because I will make some application for android one day or the other. Thanks
  • @Flick
    I'm not familiar with the frsky modules, but I imagine that the main issue will be whether you can setup the APM for that rate. I imagine arduinno can do it (certainly 9600 is no problem as far as I know).
    I'm debating between making the APK available for download, or just publishing it in the market. Will post once its available. For now the source is up at code.google.com
    Google Code
  • finally someone did it! I did the same months ago to hook google maps and a gps dashboard to my android phone because I was not able to program a gcs. bluetooth and frsky module do not interfere a lot. where can I download the apk of your gcs?
    also I use frsky for telemetry and not with ardupilot, is a pilot of myself with my protocl that is changed by a n arduino to mavlink on the ground. I ordered and apm, will apm send too many data for the 4800bps that frsky could send?
  • Bar. there is a cool item for "androids" called "IOIO" avalable on SparkFun. The board have UART's I2C and some general I/O pins (maybe for anthenna tracking)
