I'm pleased to announce that we've joined forces with the other Arduino-based powerhouse in the aerial robotics world, the AeroQuad quadcopter team, to extend the ArduPilot platform to whirlybirds of all kinds. The project, called ArduCopter, will use the ArduPilotMega and IMU shield hardware along with a low-cost custom platform that will be available commercially to provide a full quad UAV with both stabilization and GPS waypoint navigation. It builds on the awesome work of Jose Julio in ArduPilot quad development, with the excellent full-systems integration of the AeroQuad team. We expect that first code and hardware will be available this summer.
And here's the impressive work of the AeroQuad team:
Another team is also extending this to traditional helis, starting with the Trex 450 heli (and its equivalents), which should be ready for release this fall. Along with Blimpduino, this should make for 100% coverage of all aerial robotics platforms on the Arduino platform, with shared libraries and ground stations across projects. Go Arduino!
We'll be setting up a proper microsite here, along with dedicated tab, for the project in the next few days.
If you haven't already seen this preview of what the ArduPilot/ArduIMU combo can do with quads, check this out:
Here's the announcement from the AeroQuad team:
ArduCopter - The Full Featured UAV Multicopter!
Hey guys, as many of you know the AeroQuad has teamed up with DIY Drones on developing a very full featured multicopter! Chris from DIY Drones has proposed the name of this new effort to be called the ArduCopter! It will be based on the ArduPilot Pro Mega (APM) and the APM sensor board currently nicknamed the Oil Pan. Here's an initial feature list and software road map. Please chime in! Your input is valuable! I'll keep updating this front page until we agree on the first version of the ArduCopter's capabilities.
ArduCopter Feature ListSoftware Roadmap
- 6 Degree of Freedom IMU stabilized control
- Gyro stabilized flight mode enabling acrobatics (loops and barrel rolls)
- GPS for position hold
- Magnetometer for heading determination
- Barometer for altitude hold
- IR sensor integration for obstacle avoidance
- Sonar sensor for automated takeoff and landing capability
- Automated waypoint navigation
- Motor control using low cost standard PWM Electronics Speed Controllers (ESC's)
- On board flight telemetery data storage
- Mounted camera stabilization capability
- Wireless command & telemetry for long distance communication
- Capability to fly in "+", "x", hexa and octo configurations
- Battery level detection
- User configurable LED flight pattern
- Capability to use any R/C receiver
- ArduCopter Configuration and Ground Control Software
- Realtime graphs of flight data
- GUI for configuration of PID and other flight parameters
- On Screen Display integration
- Waypoint programming using Google Maps
- Mixertable view to auto configure "+", "x", hexa and octo configurations
- Initial baseline using Jose Julio's v3 software
- Provides absolute angle PID flight control
- Obstacle avoidance
- Waypoint navigation
- Generalize basic ArduCopter functions (ie. Separate PPM receiver input and motor control functions into separate libraries. Allows future coding of PWM vs. I2C ESC's)
- Emphasis on developing new capability into easy to use C++ libraries
- Integrate user defined EEPROM storage capability
- Develop/optimize AeroQuad serial real-time command/telemetry for ArduCopter
- Integrate AeroQuad Configurator for external software configuration of ArduCopter
- Rename Configurator to Ground Control Station and integrate graphical programming of waypoint navigation
- Integrate AeroQuad rate PID control
- Integrate mixertable configuration for multicopter configurations
- Integrate AeroQuad camera stabilization
- Integrate I2C motor control
- Develop capability to wirelessly control ArduCopter directly from Ground Control Station (USB joystick controller from laptop or through waypoint programming)
Would you be able to give me some advice on testing stabilised mode. I have had 8 flights now in acro and its excellent. fittted a GoPro HD camera and shot video and stills tonight with very nice results.
Quad is in X configuration and if on the ground i switch to stabilise mode, the front right prop starts to spin, as i spool up another 2 props start to spin up but the last never spins it keeps wanting to topple over all the time. I have levelled the machine and adjusted the offsets and roll and pitch now read 0 with Z at 408. The arificial horizon is level in roll and pitch.It flies so well in acro and i cant understand why stabilise is causing so many problems. Any advice on how to go about using stabilise would be really appreciated.
Thanks, T.
I have also tried some series 1 Xbee but they will not connect reliably. The wire length to my Xbee is about 7cms. Maybe I should try a differnt adapter?
What type of Xbee are you using Sebastian?
Peter
My Xbee settings what I use are rather normal. From X-CTU program:
Modem: XBP09-DP, XBEE-PRO 900
Version: 1002
NI - Node Identifier: 900GR (for ground), 900AIR (for AIR xbee)
EE - Encryption: enabled
DB - Baudrate: 115200
RO - Packet timeout: 0
PR - Pullup resistor enable: 3F7F
Everything else are on their defaults. I don't even remember why I activated PR but I think it was due I planned to use Xbee to upload software via wireless. Encryption can be switched off, I just keep it on due security reasons.
You seem to be a little further than I am getting the xbee’s working. I have Xbee-Pro Series 2 2.4Ghz, can’t get them to even connect to the configurator. I started by using the wiki info and ran the MultiSerialMega.pde successfully, even if I take the coordinator and switch it with the configured as the router/ end device. But it will not connect to the configurator.
Thanks,
Scott
So even tho the IMU and blades might be at a different height you are saying it doesn't matter if they are not level on the same plane to each other. Can you explain further please.
Thankyou.
T
I have been struggling to get my Xbee link working. Can you tell me more about the Xbee settings on your system that works?
Peter
Surly it matters if the arms are not level. If the imu is not level to the arms/motors and the acc are calibrated to the imu then would there not be an angle on the motors and therefore the quad would try to move in that direction even tho it is keeping the IMU level?
T
I always put spirit/bubble gauge/or what ever device on top of IMU due Arms and other does not matter if they are or are not level. Yes most cases leveling arms will take you rather close but then again.. There might be minor differences on your imu. It is IMU that makes measurement no Arms :)
21
22
23
24
25
of 82 Next
