I'm pleased to announce that we've joined forces with the other Arduino-based powerhouse in the aerial robotics world, the AeroQuad quadcopter team, to extend the ArduPilot platform to whirlybirds of all kinds. The project, called ArduCopter, will use the ArduPilotMega and IMU shield hardware along with a low-cost custom platform that will be available commercially to provide a full quad UAV with both stabilization and GPS waypoint navigation. It builds on the awesome work of Jose Julio in ArduPilot quad development, with the excellent full-systems integration of the AeroQuad team. We expect that first code and hardware will be available this summer.
And here's the impressive work of the AeroQuad team:
Another team is also extending this to traditional helis, starting with the Trex 450 heli (and its equivalents), which should be ready for release this fall. Along with Blimpduino, this should make for 100% coverage of all aerial robotics platforms on the Arduino platform, with shared libraries and ground stations across projects. Go Arduino!
We'll be setting up a proper microsite here, along with dedicated tab, for the project in the next few days.
If you haven't already seen this preview of what the ArduPilot/ArduIMU combo can do with quads, check this out:
Here's the announcement from the AeroQuad team:
ArduCopter - The Full Featured UAV Multicopter!
Hey guys, as many of you know the AeroQuad has teamed up with DIY Drones on developing a very full featured multicopter! Chris from DIY Drones has proposed the name of this new effort to be called the ArduCopter! It will be based on the ArduPilot Pro Mega (APM) and the APM sensor board currently nicknamed the Oil Pan. Here's an initial feature list and software road map. Please chime in! Your input is valuable! I'll keep updating this front page until we agree on the first version of the ArduCopter's capabilities.
ArduCopter Feature ListSoftware Roadmap
- 6 Degree of Freedom IMU stabilized control
- Gyro stabilized flight mode enabling acrobatics (loops and barrel rolls)
- GPS for position hold
- Magnetometer for heading determination
- Barometer for altitude hold
- IR sensor integration for obstacle avoidance
- Sonar sensor for automated takeoff and landing capability
- Automated waypoint navigation
- Motor control using low cost standard PWM Electronics Speed Controllers (ESC's)
- On board flight telemetery data storage
- Mounted camera stabilization capability
- Wireless command & telemetry for long distance communication
- Capability to fly in "+", "x", hexa and octo configurations
- Battery level detection
- User configurable LED flight pattern
- Capability to use any R/C receiver
- ArduCopter Configuration and Ground Control Software
- Realtime graphs of flight data
- GUI for configuration of PID and other flight parameters
- On Screen Display integration
- Waypoint programming using Google Maps
- Mixertable view to auto configure "+", "x", hexa and octo configurations
- Initial baseline using Jose Julio's v3 software
- Provides absolute angle PID flight control
- Obstacle avoidance
- Waypoint navigation
- Generalize basic ArduCopter functions (ie. Separate PPM receiver input and motor control functions into separate libraries. Allows future coding of PWM vs. I2C ESC's)
- Emphasis on developing new capability into easy to use C++ libraries
- Integrate user defined EEPROM storage capability
- Develop/optimize AeroQuad serial real-time command/telemetry for ArduCopter
- Integrate AeroQuad Configurator for external software configuration of ArduCopter
- Rename Configurator to Ground Control Station and integrate graphical programming of waypoint navigation
- Integrate AeroQuad rate PID control
- Integrate mixertable configuration for multicopter configurations
- Integrate AeroQuad camera stabilization
- Integrate I2C motor control
- Develop capability to wirelessly control ArduCopter directly from Ground Control Station (USB joystick controller from laptop or through waypoint programming)
Yes there will be specially designed motors for ArduCopter use, 2 sizes smaller and bigger. Motors, ESCs, Props, Frame sets and Frame parts can all be purchase separately too after everything is ready. All Motors will have 35 cm long wires with connectors.
Products will be found from DIY Drones eshop, PhiFUN eshop and there will be also few distributors around world.
Due we are making some organizational changes, PhiFUN might be change in close future but we will inform it and address will be working during transition time.
The size of the pcb is 50/50mm
Thank you,
Leonardo
thx, how many mAh? which discharge rate?
I used to have NiCd batteries in my RC cars, but they seems a bit too heavy for the copter :)
Any recommendation on a battery and charger?
Thx
While I'm about to order some stuff from HK, I was thinking I could buy something more (to spread the shipping cost a bit). What will the kit include? Just the frame? Or will it include everything except the Rx/Tx? Or is there something else I need to buy that is not included, like batteries, recharger and so on?
Thx
Simone
sorry, link to tutorial for changing from mode 1 to mode 2 doesn't work.
Do you know the size of the trex450 landing gear? Can´t find that info in anywhere...
I havnt flown it yet. Had this Mikrokopter chassis for a while and finally put it to use. Been waiting on the mail(takes forever) for some silicone wire and other little parts to complete this. Thanks for the tip on the battery. Might do that.
Cláudio,
I was looking at Maxs landing gear also trying to figure out what brand they were. Just ordered trex450 gear for mine. Trying to find some that stood taller though. Anybody have any suggestions? I absolutely refuse to pay $50 for a set of gear from mikrokopter!
11
12
13
14
15
of 82 Next
