The Science of Successful antenna design
As promised, James, Brad and Hughes, and anyone else interested, some info on turnstiles and the methods of antenna matching.
James made the following statement:
I came across this link http://www.fpvmanuals.com/category/manuals/equipment-manauls/antennas/ which explains how to build what they call a turn stile antenna. Could anyone try and explain why this antenna would work as I had really poor performance with it. I ended up using a simple cross dipole on the RX side with much better results.
I gave the start of an answer in a long reply which can be found in his post : 433 UHF LRS Antenna "Turn Stile"
Some further questions where asked regarding the methods of match the antenna, and the antenna tuning, so I will try to elaborate.
First some fundamentals.
When I speak of antenna radiation it also includes the reverse, that is, the antenna 'collecting' radiated energy from the ether.
Any piece of wire will radiate energy when connected to a source of RF ( Your transmitter or receiver). How WELL it radiates that applied energy is dependent on only two factors-
- That the antenna is resonant at the same frequency as the radio signal applied and
- That the feedpoint of the antenna is matched to the impedance of the attached transmitter energy source.
Maximum energy tranfer between source and load ( the antenna) occurs ONLY when the load and source impedance's are equal.
How well the antenna radiates that energy in any or all directions, if the above conditions are met, is then only dependent on the antenna design, shape, or style. For example, a simple vertical 1/4 wave radiator will radiate a doughnut shaped pattern, in all direction of the compass, with low energy upwards and downwards, in the direction of the antenna element.
A yagi type antenna, on the other hand, ( such as your vhf or uhf TV antenna) focuses the energy in a single direction, as would a torch. Antenna do not have gain. They focus the energy to a greater or lesser extent, in a direction of design, but do this by robbing energy from other radiating directions - Your torch puts more light out the lens end, with nothing out the rear end. If you remove the reflector from behind the torch bulb, the light is radiated in all directions, omnidirectionally, but is much weaker at any distant point than the focused beam.
Antenna radiation is polarized; that is to say, the radiated electromagnetic wave has a net polarization plane. This is usually either linear or circular. Elliptical polarization is also found, but that is merely a mix of the two former types.
A 1/4wave vertical antenna will radiate linearly, with vertical polarization. Placed on its side it will radiate horizontal polarization. A Helical antenna ( looks like a coil of wire wound in a screw fashion) wound clockwise when viewed from behind will radiate clockwise circular polarization, and vise versa.
For reception of maximum energy, the two antenna must be identically polarized. There is a massive loss of signal ( easily some 30dB, although the theoretical loss is infinite) if one attempts to receive a horizontally polarized signal with a vertically polarized antenna. Similarly, there are massive losses if trying to receive a circularly polarized signal with an antenna of the opposite circular sense.
The odd man out is that there is only a 3db loss between an antenna that is circularly polarized and one that is linear.
Why would one use circular polarization?
If the two antenna in question could not be made to maintain similar attitudes, such as one in a pitching , rolling aircraft, then there would be unacceptable signal losses as the aircraft banks and pitches. So you could use a vertical on the aircraft, and a helical or turnstile, or similar, on the ground segment. This way you would only ever experience a 3db maximum loss. ( all assuming good line of sight view). Or you could gain back the 3db loss by fitting a similar circularly polarized antenna on the aircraft, giving the best of both worlds. But you actually gain more than that with circular polarization at both ends.
Assume first that the two antenna are simple vertical monopoles, radiating vertically polarized signals. When you are flying, at the flying club, etc, you are probably near some metal structures, the 'hanger' , cars and other vehicles, etc. All these structures reflect the same energy you are trying to receive. In addition, when the aircraft is low and far, the RF transmitted by the A/C antenna follows two paths to your receiver - one directly, and one via a reflection from the ground, somewhat midway between you and the A/C. What happens to the reflected wave is that the polarization is changed in unpredictable ways. Your receiver ( and antenna) does not know or care where the received energy comes from, so it receives this reflected energy as well. These multitude of received waves add constructively and destructively with the main received wave, causing large, short duration, signal drop-outs - a sort of 'flutter' in the signal.
If both antenna are circularly polarized, however, the picture is quite different. When the circular polarized waveform is reflected , it REVERSES its polarization. When this reversed polarized signal arrives at your receiving antenna it is largely rejected and hugely attenuated, so interfering minimally with the main received signal.
On to Issues of resonance and matching.
To repeat a little in my post to James:
Most simple linear antenna are either of the monopole or dipole form. A single monopole ( 1/4 wave vertical for example) or a single dipole will only radiate linear polarization.
Any antenna is only resonant when it is exactly the correct length AT the frequency of operation.( this does not apply to the class of broadband antenna, such as helical antenna, etc. The helical will easily cover an ocatve with good performance).
At resonance the antenna will exhibit its characteristic feedpoint impedance. Feedpoint impedance is expressed with two terms, the pure resistive part, and the reactive ( j operator) part.
Most transmitters and receivers terminal impedance are made to be 50ohms resistive, or very close to that. So it stands to reason the antenna must also be 50ohm resistive to have max energy transfer. However, none of the antenna are that obliging, so we have to do some feedpoint matching to meet the criteria.
A 1/4wave vertical monopole over a ground plane has a resistive feed point of around 75ohms. A half wave dipole is around 72ohms. As with resistors, placing two dipole in parallel as in the IBcrazy turnstile, will result in a feedpoint impedance of 35ohms.
A 75ohm feed connected to a 50ohm coax and transmitter will exhibit a 1.5:1 SWR ( the ratio of power going out to power reflected). A 1.5:1 SWR means that approx 3% of your transmitter power is not being radiated. ( 30milliwatts for a 1watt transmitter). That is not so bad, and we can live with an SWR of 1.5:1 in most cases.
The turnstile antenna is a pair of crossed dipoles, fed 90deg out of phase with each other, thereby generating circular polarisation. You CANNOT simply connect the dipole in parallel at the coax feedpoint though. Apart from the halving of impedance ( which we decided we can live with) the radiation pattern and polarization of the antenna will be totally destroyed by unwanted radiation from the coax cable. The RF energy, at the dipole connection point, 'leaks' out and currents then flow down the outer shield of the coax. As mentioned previously, any piece of wire will radiate RF energy, and so the coax radiates this energy, and the radiation again adds constructively and destructively with the main antenna radiation, causes complete distortion and signal nulls in the pattern. This radiation from the coax MUST be prevented.
This is done by means of a Balun transformer. - which is is an acronym for 'Balanced to Unbalanced transformer'.
A dipole is a balanced device - it is electrical equal along each element, outwards from the feedpoint. It therefore requires that the feedpoint be fed in a balanced fashion. Coax cable is an an balanced feeder - the shield is at ground potential, while the inner core carries the energy. This effectively ( oversimplifying a little) connects the one dipole half to the 'live' core, and the other half to 'ground' unbalancing the dipole. This causes currents to flow on the coax outer shield, and distortion of the dipole radiation pattern.
Baluns can be constructed from coax cable, but the accuracy required in coax cable length ( they are normally length multiples of 1/4 wavelength) is very critical, especially in the GHz range - 0.5mm can have a great effect.
The turnstile is not new - it is some 50 to 60 years old, and is well researched and published. Up to the VHF and lower UHF region , the coax balun, with embedded impedance match transmission line transformer, is used, along these lines:
For the higher microwave frequencies, a plumbing type version is more appropriate. This is called the spilt tube or split sheath balun, and looks like this when used as a feed for a pair of crossed dipoles.
The balun and feed match consists of an outer and an inner tube. The ration of diameters D/d is chosen to give the desired impedance:
D/d = 1.86 for 75ohms, and 1.5 for 50 ohms.
Typically the outer tube would be around 8mm for use at 2.4GHz.
In order to obtain circular polarisation, I mentioned that the two dipole have to be fed 90deg apart ( phase quadrature).
This can be done as in the coax balun version above ( inserting an extra 1/4wave length of coax in the leg to one dipole gives an extra electrical wavelegnth of 90 degerees).
Or, this can be achieved by slightly lengthening the one element ( becomes more inductive) and shortening the other( becomes more capacitive) - this also introduces the required phase difference between the elements.
This can be seen in the images above - the one element is typically around 0.21 wavelength per half, while the other is around 0.25 wavelength. One short and one long element penetrate the outer tube and are connected to the inner tube, while the opposite pair of elements are connected only to the outer tube. The outer tube is split or slotted ( 0.5mm width slot). The slot is approx 0.23 wavelength long.
The relationship in length between the two dipoles is critical, typically this would be measured on a network analyser and the feed impedance of each element set to say R+j45 ohms ( longer dipole) and the other to R-j45 ohms. This will give the correct phase relationship between elements. A half mm variation can have a great effect, turning a good antenna into a mediocre one..
The last image above shows a teflon tube - this is inserted in the tube from below, and fits snugly inside the outer tube, and over the inner tube. This is then slid up and down to adjust the 'R' part of R+-jX, till the match is a good 50ohms. This does not affect the antenna radiation pattern or characteristics. Obtaining a 50ohm impedance match can be done by trimming the element lengths as well, at the same time destroying the antenna radiation pattern and circularity.
And that is why it is not so simple to do at home, and why the 'Hobby King' et al variants sold everywhere are mostly trash..You will probably achieve a few km range with those- remember, any old piece of wire will radiate - I easily achieve 15km with 500milliwats at 2.4GHz using two split sheath balun , properly matched and trimmed, crossed dipoles..
For those interested:
References are - RSGB VHF/UHF Manual - page 8.45
Modern Antenna Design - Page 255
Here are some images of my split sheath balun crossed dipoles..
Joe
The Nampilot.
Great post, thanks for explanation! :)
Hi Joe,
Some great info here. Thanks a lot for sharing it. Quick question. Are the two diagrams you posted of the turnstile antenna (one with 75 ohm feeder and one with 50 ohm feeder) considered to be balanced. If so, it is unclear to me which part is the balun. If not, how would you add a balun? Also, I am trying to figure out how to best add a balun to a simple dipole.
A short followup for my earlier posting about my intent to try circular polarized antennas. The general results are either uninspiring or terrible. For the 2.4GHz FHSS video link, I tried a set of Blue Beam Ultra. These actually cut the range by at least a third. I also tried a Blue Beam Ultra with a Crosshair on the receiving end. No improvement. And as a sanity check, I swapped the three and five lobe antennas. No difference.
As for the 5.8 GHz analog rig, I tried a pair of SpiroNet antennas. Inside a steel building, the improvement in signal quality is good but it doesn't improve range.
I wish these RHCP antennas had gain ratings on them because what I may be making up in elimination of multi-path problems I'm probably losing in gain.
So, sadly, it seems that there is no substitute for raw power output and antenna elevation above ground level.
Will post this evening Albert - The Coax collinear works well, but not easy to trim - you will need an SWR meter..but there are better - later..
Joe
I love this elusive topic and your help.
I recently searched for antennas with high gain and a flat radiation pattern.
I found something called a CoCo, coaxial collinear, apparently it can be end fed or center fed. Could you please let us know what you know about this design and if it will be suitable for our purposes ?
Many thanks
Albert
Thanks for that response, Joe. That helps a lot. I recently was range testing a FHSS video link (125mW output and 5dB antennas) and I could only get 500 meters with it on level ground. I had previously tested the rig at a different location where one end of a mile long road was at least 30 feet above the rest of the road and I could get all the way out to a mile with it. Today I decided to go back to the level ground site and put the Tx antenna up on an 8 foot ladder. Big improvement. Not a mile but at least 1000 meters.
I also have a 1000mW 5.8GHz analog video link. That works well with standard whip antennas on level ground but interference comes and goes. Online calculators tell me that higher frequencies have shorter obstacle height so this makes sense. Although I'd like to know if there's a way to calculate signal loss in dB to antenna heights.
I've ordered some circular polarized antennas to see how that changes things.
Joe,
I would just like to add my thanks for the time you are investing in this conversation.
As a budding FPV'er this has to be one of the hardest subjects to grasp, and one of the most important.
I am all ears!
Ross
Hi Nikola;
Hope this post did not double - it seem to disappear..had to re-enter it..
You are quite correct in your analysis. You don't really lose signal, rather the signal cancels itself out..Assuming open line of sight between the two antenna, the Fresnel zone is the dominating influence of the quality of the signal received. If the TX signal is reflected off an obstacle in the receive path, it will arrive at the receiver with a different phase relative to the main signal. If it arrives shifted by 180 degrees( or multiples thereof) , it partially cancels the main signal, resulting in a large signal loss. This effect is present even with a ground station antenna and the TX in a plane some 100's of meter up in the sky. In this case , however, the number of reflections reaching the RX antenna is few, mostly only one, and much reduced in strength. This is easily coped with by employing circularly polarized antenna at both ends - a reflection will reverse the polarity and the receiving antenna, if it has a good axial ratio, or good circular performance, will largely reject that signal.
However, when both antenna are so close to the ground, there are many reflections along the path to the RX antenna. There are a number of Fresnel zones related to the antenna heights, distance apart, and height of obstacles in the receive path.
Obstacles in the first Fresnel zone will create signals with a path-length phase shift of 0 to 180 degrees, in the second zone they will be 180 to 360 degrees out of phase, etc. Even numbered zones have the maximum phase cancelling effect and odd numbered zones may actually add to the signal power.
The situation could not be made worse with the Rover - the antenna are so close to the ground, you will always suffer these effects.
The only way to help the situation is to have highly directional, narrow beam antenna, so that the signal of-beam is very weak as it reflects from the ground. That does mean tracking antenna, etc.
Joe
Fascinating (and frustrating) stuff. I have a related question and it's more about real world than theoretical. Most folks are doing FPV on a UAV. What about a rover? I've played around with Friis equation solvers that tell me I should be able to get several miles of range on a 125mW 2.4 GHz link. I've also read that Fresnel effect will significantly reduce signal when the antennas are close to the ground even though you may have perfect line-of-sight. Supposedly, the signal isn't laser-beam straight but rather is more like a loose string between the two antennas. If the sag intersects the ground, you lose signal. Care to comment?
@iskess'
Have a look at my comments to Justin on TX/RX bandwidths and mutual interference. By default, the low cost of the modules used in this typical application means that many compromises have been reached in their design and implementation. The main compromises are always in the front end selectivity and the ability of the front end RF preamplifier and the first mixer to withstand out of band and/or strong signals. So , yes, it is always better to try and keep these modules as far from each other as possible. But any co-location issues on the aircraft are fairly easy to detect and test for - simply tape the antenna in place and test the system with all systems active. You do not need to move the aircraft far from the ground station, etc, since the problems will manifest on the aircraft only.
The Inverted V, when employed as an inverted V, has an 'almost' omnidirectional pattern, which eliminates the signal nulls of the end of a conventional dipole. However, the inverted V also has less gain than a dipole, maybe half, but agonising over 1 or 2dB is a waste of energy - it will make no real difference at all.
Not that in my diagram the inverted V is in fact a side-ways V, but the pattern will be relatively unaffected. It will work just fine. The compromise is required in order to get it to fit in your available space.
Your question 2 is covered - the advantage is a more omnidirectional radiation pattern - also it is more easily matched.
Here is a design for a 5/8 base loaded antenna at 915MHz. I used exactly this on our Hornbill aircraft ( if interested, search for Hornbill in my earlier blogs..) with a 915MHz, 1watt Digi modem, and on ground I used a 10 element Yagi - we got 12km range easily, while only achieving 4km with a 1/4 vertical on the plane, and 9km with a vertical diople.
NOTE: there a number of 'designs' for the 5/8 vetical. The highest gain design is the one I show below, and if done and matched perfectly, will give around 4dBD ( that is 4db gain greater than a dipole!) . The design concepts are as follows:
A 1/4 wave antenna radiates omnidirectionaly with a contiguous radiation pattern. Its gain is quite low, and its capture area, a function of its size, is low. A 1/2 wave vertical has much higher gain, contiguous radiation pattern, a greater capture area, but its feedpoint is at a high voltage point, so has a very high impedance and is difficult to match. A 3/4 wave antenna also has a high gain, even greater capture area, and the feedpoint is a much lower impedance, and easy to match. However, the 3/4 wave antenna starts to exhibit a break up of the radiation pattern into a number of main lobes, with in-between nulls. We can now combine the trait of increasing gain and ease of matching for longer antenna, by making the main element 5/8 wavelength long, and fitting a coil at the bottom that is an electrical 1/8 wavelength long. This gives a 3/4 wave electrical length antenna, but only 5/8 log physically - the coil does not radiate appreciably. So we get a very good radiated pattern, high gain, and an easy match.
Here are also some picture of the antenna as I fitted and used it on our Hornbill aircraft.
Note that it was fitted upside down, not ideal as the shape of the radiated signal is not optimum this way.
1
2
3
4
5
of 7 Next
