APM 2.012 + REMZIBI OSD
With the APM together, it can display much information on the screen, e.g. the attitude of the plane, GPS data, NAV data, etc. The details of displayed information can be found in the web site of Remzibi OSD and the ARDUmV1_71.txt. Blake Krone has done great works to integrate the OSD and the APM. However, due to the fast development of the APM, some source codes are out of date, and thus a few modifications are needed to make them work properly. In this article, we give a detailed instruction of those modifications.
Our work is based on
1. APM 2.12 source code. Arduino-0022 IDE.
2. The firmware of OSD is ARDUmV1_71.hex
3. The serial port of the OSD is connected to serial port 3 of the APM (i.e. Telemetry port). Because the OSD does not send data to APM, the TX pin of the OSD is not required to be connected. You can also connect the Xbee to the serial port 3 of the APM in the meantime. In such case, the RX pins of the Xbee and the OSD are connected in parallel, and You MUST NOT connect the TX pin of the OSD. The Baud rate of the OSD is self-adaptive, and it is usually below 115200.
Here are the modifications:
First, download OSD_Remzibi.pde, and then modify some parameters according to the definitions in the code of APM:
1. In function print_osd_data(void)
Original:                    SendSer(GPS.date,DEC); //Date
Modified:       SendSer(g_gps->date,DEC); //Date
Comment:     This parameter is the GPS UTC date
Orignal:             SendSer(GPS.time,DEC); //Time
Modified:       SendSer(g_gps->time,DEC); //Time
Comment:     This parameter is the GPS UTC time
2. In function void print_osd_ahrs(void):
Original:         SendSer((pitch_sensor/100) * -1,DEC); //Pitch
Modified:       SendSer(dcm.pitch_sensor/100,DEC); //Pitch
Comment:   This parameter is the pitch of the plane.
Original:         SendSer(roll_sensor/100,DEC); //Roll
Modified:       SendSer(dcm.roll_sensor/100,DEC); //Roll
Comment:     This parameter is the roll of the plane.
Second, modify the source of APM (ver 2.12):
① In APM_Config.h :
Add following codes:
#define OSD_PROTOCOL OSD_PROTOCOL_REMZIBI
#define OSD_PORT 3
#define OSD_MODE_CHANNEL 7
These macros tell the APM to use the serial port 3 to connect to the OSD under the REMZIBI protocol. The channel 7 is used to control whether the OSD displays. You can change the serial port or control channel if it is needed.
② ArduPilotMega.pde :
In function medium_loop(), add following codes before the break statement in case 3:
#if OSD_PROTOCOL != OSD_PROTOCOL_NONE
print_osd_ahrs();
#endif
In function slow_loop (), add following code before the break statement in case 1:
print_osd_data();
#endif
// Read OSD Mode Switch
#if OSD_PROTOCOL == OSD_PROTOCOL_REMZIBI
read_osd_switch();
#endif
③ defines.h :
Add following codes after “//GPS type codes”:
// OSD type codes
#define OSD_PROTOCOL_NONE -1
#define OSD_PROTOCOL_REMZIBI 0
④ commands.pde :
In line 251, add following code at the end of function init_home():
// Save Home to OSD
osd_init_home();
#endif
Now, all the modifications have been done. Copy the OSD_Remzibi.pde to the folder of the source code of the APM 2.12(APM Trunk\ArduPilotMega), start Arduino, build the sketch and upload to the APM.
3689404993?profile=original
 3689404945?profile=original
Uploads are not downloaded,Why?ArduPilotMega2.12+remzibi_osd.rar
OSD_RemzibiV2.pde
chineseV.pdf
Thank LEE,hazy,Blake Krone's
  • Did you set feet or meters in the osd_remzibi.pdt
  • You are not using the telem port (port 3) ?
    port 0 is the usb, who did you manage to connect the osd to it?
    the osd might have a hard time parsing out the binary protocol that is already on the same port
  • Boutrate is max: 115200 (most of the time)
    Here is my apm_config.h
     // -*- tab-width: 4; Mode: C++; c-basic-offset: 4; indent-tabs-mode: nil -*-
    // This file is just a placeholder for your configuration file.  If you wish to change any of the setup parameters from
    // their default values, place the appropriate #define statements here.
    // For example if you wanted the Port 3 baud rate to be 38400 you would add a statement like the one below (uncommented)
    //#define SERIAL3_BAUD        38400
    //#define GCS_PROTOCOL        GCS_PROTOCOL_NONE
    // You may also put an include statement here to point at another configuration file.  This is convenient if you maintain
    // different configuration files for different aircraft or HIL simulation.  See the examples below
    //#include "APM_Config_mavlink_hil.h"
    //#include "Skywalker.h"
    // The following are the recommended settings for Xplane simulation. Remove the leading "/* and trailing "*/" to enable:
    #define HIL_PROTOCOL        HIL_PROTOCOL_MAVLINK
    #define HIL_MODE            HIL_MODE_ATTITUDE
    #define HIL_PORT            0
    #define GCS_PROTOCOL        GCS_PROTOCOL_MAVLINK
    #define GCS_PORT            3
    #define OSD_PORT 0
    I have a similar setup running in APM 2.1 with OSD on port 3 (57600) and GCS on port 0 (115200), both Work just fine. I added some messages based on flight mode and others to report pan and tilt angles. I also had issues with OSD not turning back "ON" and made similar changes. I find that data is sent to OSD Video link faster than down to HK_GCS over Mavlink, I am hoping to get Mavlink to send Ascii data to OSD mixed along with binary data to GCS.to free port 0. I think using debug type messages will work, but I have had no time to build and test. OSD should ignore binary, Mavlink will need to skip OSD Ascii messages. AH is faster than Mavlink attitude display.
    All based on Blake's original post.
  • At what speed does it sync for you?
    2.1 works fine for me.
    can you post you apm_config.h as well
  • Also the skybar is moving very slow and the timer stops from time to time.
  • Ok, I got this to work.
    But my numbers and symbols on the screen are flickering wild and disappearing. I see this a little on the video's above, but here it's really extreme.
    Could it have to do that I used the 2.1 firmware in stead of the 2.012 ? Or had it something to do with de remzibi's firmware/layout.
  • Hi Matthias.
    I had to change the code to get it to work switching off then on again. Switching off was always possible.
    I changed the code to this;
    byte oldOSDSwitchPosition = 1;
    void read_osd_switch()
        byte osdSwitchPosition = readOSDSwitch();
        if (oldOSDSwitchPosition != osdSwitchPosition){
            switch(osdSwitchPosition)
                case 1: // First position
                set_osd_mode(1);
                break;
                case 0:
                set_osd_mode(0);
                break;
            oldOSDSwitchPosition = osdSwitchPosition;
    byte readOSDSwitch(void){
          int osdPulseWidth = APM_RC.InputCh(OSD_MODE_CHANNEL - 1);
        if (osdPulseWidth < 1000)  return 0;    // Off
        return 1;
    void set_osd_mode(byte mode){
            switch(mode)
                case 1: // On
                            SendSerln("$CLS");
                            SendSerln("$L1");
                break;
                case 0: // Off
                SendSerln("$L0");
                            SendSerln("$CLS");
                break;
    Of course the set_osd_mode(xx) value must match the values possible in the switch() case inside it. Same goes for read_osd_switch() must return a code that matches the switch() case in read_osd_switch(). The code above works for me now. I might have changed it, and then changed it again to make it work, but i think there was an issue there. Compare it to the real code then you will see... I think... :)
  • I flew with this , during the week-end .The experience was very solid.
    I have just a few things for the wish list that I may implement myself:
    - I connect the OSD after the APM and the APM has already "set home" when I connect the OSD. It would be nice to activate "set home" with a switch or in some automatic way.
    - Maybe changing the ground speed osd with the airspeed when available.
    @thomas :check the function read_osd_switch. The code seems ok to me.
    Thanks to all the people who made this integration.
  • Found a bug in your code handling the on/off switch.
        if (osdPulseWidth >= 1450)  return 2;    // Off
        return 1;
    void set_osd_mode(int mode){
            switch(mode)
                case 1: // On
                            SendSerln("$CLS");
                            SendSerln("$L1");
                break;
                case 0: // Off
                SendSerln("$L0");
                            SendSerln("$CLS");
                break;
    the readOSDSwitch() function needs to return either 0 or 1, or the case statement bellow needs a change..
    They way it wokrs now is, on, off, and never on again...
    Nice work by the way..!!
