3689451783?profile=original
One of the priorities of the APM team is to continue to find new ways to make it easier to use. The Mission Planner is a big part of that, with it's one-click firmware loading, but author Michael Oborne has now done it again with a great installation utility (64-bit Windows here, 32-bit here) that not only installs the Mission Planner, but also detects which APM you have and installs the right driver for it. That's like five manual steps eliminated!
Great work, Michael!
(As always, it will also check for updates at startup and download the latest version)
  • Micheal O is a programming GOD!!! The MP in all it's forms is a work of programming art and tech. I'm a really big fan
    TOM
  • I'm embarrassed to admit it,but once again the problem was me.  I forgot that you have to click the "Connect" button...  Painful lesson learned. I think I will stick with the JR R1221 receiver.  Do you have any suggestions about the best placement for the outboard receivers ?
    Thanks for all your help!
  • No luck with a JR R1221 either... in all cases, I can operate a servo plugged into an extra channel, so I don't think it is a radio binding issue... ?????
  • O.K... I'll try another receiver....
    Thanks!
    -Taylor
    Taylor: Have you followed the advice in the Troubleshooting section? The AR8000 is notoriously finicky.
  • I'm moving forward... SLOWLY.  I got my Spektrum AR8000 receiver hooked up, and have my JR 11X bound to it.
    With the four ESC controller leads disconnected, a 3 cell LiPo pack connected, the radio appears to be working (AT least I have control of a servo plugged into an extra, Aux 2 channel).  But no matter what I do, no sign of life comes up in the "APM Setup" window... just blank gray bars....
    I've tried re-loading the firmware... but have run out of ideas ?????
    Taylor: Thanks for the update -- glad it's resolved!
  • I have met the enemy and he is Me!.... I discovered that the USB cable that I was using was intended for charging purposes only, and has only the power connections... no data.
    I went out and bought the correct cable, and Windows 7 immediately recognized the Arduino card, found the proper drivers, and it now shows up as Com 6 in the drop down window.
    Thanks for the help!
    -Taylor
    Taylor: That's really weird. And you've got the APM board plugged in when the Mission Planner starts?
  • If I try to download the Quad firmware, I get a terse message that says..."Failed to download new firware: Sytem Argument Exception: The given port name does not start with COM/com or does not resolve to a valid serial port.... and a bunch of other stuff.  I can do a screen capture if this is meaningful....
