The new ArduPilotMega Shield "Hotel' Version 1.0 has finally replaced our old and problematic Foxtrap 2.2, many of the changes are just to accelerate the assembly process and reduce production failure rates, working in conjunction with the very supportive Invensense Team (Thanks guys!).
Note: if you are a user with the current boards, they're fine. The problems were in the production process, which required us to go through extra steps to ensure they passed QA. The new board is more for our sake than yours!
Manufacture changes:
-Improved gyro pads.
-The boards now came with Lead-Free Silver Immersion for an even surface (Turns goldy when baked).
-Added one 0603 resistor pad on voltage divider for automatic machine placement. I should have added it to all the resistors. =/
User Experience:
-Now that is easy to assemble, boards availability will be improved.
-Solder jumpers to optionally enable/disable gyro low pass filters.
-Added labels that suggest where the female headers should be placed.
Bugs fixed:
-Reset button now works under any condition.
-Analog supply for the pressure sensor is now attached to the analog 3.3 voltage regulator.
By the time I wrote this post I still had some Oilpan in stock, please hurry because we are moving to a new warehouse and we may be out for around one week again, just in time to start production with our new Japanese made Manncorp 7722V. Many thanks to the Mancorp team that is also located next to us in San Diego,CA!
Eagle Files:
Also many thanks to Star Wars (TM)!
I look forward to purchasing another board once I can catch them available in the web store (ahh! makes me so mad to learn that some were available the other day. I've been ready to purchase for weeks)
Personally, I think the price you guys have right now is untouchable, unless someone with some serious capital had some deep enthusiasm for UAVs.
I'm "fighting" with this same issue when building ArduCopter frames and base electronics. When dealing with manufacturers like motor / esc or so. Minimum order qty is 1000 - 2500 units to get even some level of reasonable price. Or just like aluminum square tube that we are using on ArduCopter frames, MOQ 600 meters. (I got another really low and great price for that from China but problem was that MOQ 10 Metric tons ;) )
So If you can get better pricing or deals, like Chris said... We are more than happy to hear about it.
Based on what you calculated the price for the oilpan to be at least $100? ;-) With profit for you and at least 30% for re-seller's/distributors...
It should be atleast 100 dollars the most
quote: "... Check out PicoPilot instead ;-) "
Boy that was a surprise coming from you Chris... sorta like my snotty standard reply to window shoppers here at DIYDrones, telling them to try Walmart.
1
2
3
of 3 Next
