APM Oilpan Rev. H, Version 1.0 now in production!
The new ArduPilotMega Shield "Hotel' Version 1.0 has finally replaced our old and problematic Foxtrap 2.2, many of the changes are just to accelerate the assembly process and reduce production failure rates, working in conjunction with the very supportive Invensense Team (Thanks guys!).
Note: if you are a user with the current boards, they're fine. The problems were in the production process, which required us to go through extra steps to ensure they passed QA. The new board is more for our sake than yours!
Manufacture changes:
-Improved gyro pads.
-The boards now came with Lead-Free Silver Immersion for an even surface (Turns goldy when baked).
-Added one 0603 resistor pad on voltage divider for automatic machine placement. I should have added it to all the resistors. =/
User Experience:
-Now that is easy to assemble, boards availability will be improved.
-Solder jumpers to optionally enable/disable gyro low pass filters.
-Added labels that suggest where the female headers should be placed.
Bugs fixed:
-Reset button now works under any condition.
-Analog supply for the pressure sensor is now attached to the analog 3.3 voltage regulator.
By the time I wrote this post I still had some Oilpan in stock, please hurry because we are moving to a new warehouse and we may be out for around one week again, just in time to start production with our new Japanese made Manncorp 7722V. Many thanks to the Mancorp team that is also located next to us in San Diego,CA!
Eagle Files:
ArduPilotMegaShield_H_v10.brd
ArduPilotMegaShield_H_v10.sch
Also many thanks to Star Wars (TM)!
Comment by Jeffrey batista on September 18, 2010 at 8:57pm
Is there an exact date on the release of the new board hotel?
Comment by Jani Hirvinen on September 19, 2010 at 10:07am
I think that Jordi said it on topic and on first sentence of this posting :)
Comment by Öncü Kayalar on September 19, 2010 at 10:31am
Nice sign on the board.. May the force be with you :)
Comment by Max Levine on September 19, 2010 at 5:14pm
Jordi, can you pleas explain more about the acc filters ?
Do I need to get new board to fly arducopter, will it perform better ?
And how do I change tis filters on the old board ?
Comment by Jani Hirvinen on September 19, 2010 at 5:24pm
Max, this new board has all same components than Foxtrap was. Both of them fly the same but main issue was with 3 capasitors that acts as filters to accelerometers. Some people say that without those capasitors quad flies better but for fixedwing people capasitors must be there. So Jordi just made small modification which is solder jumper to disable/enable those capasitors.
We are still looking and testing behavior of these filters due there are a lot of conflict on our field tests that we try to find. On older IMU filters can be disables by removing those 3 small capasitors. But as I have flown with and without them... I have not seen any difference.
So old Foxtrap board is as good as this Hotel board.
Comment by Chris Anderson on September 19, 2010 at 6:55pm
I'm flying with them, and see no problems. We've tested this one to death, and we can't confirm that that caps cause a performance degradation. But as Jordi says, if you ultimately don't want them, they'll now be easy to disable. (I'm going to keep mine)
Comment by Jeffrey batista on September 19, 2010 at 9:03pm
Chris so the price will stay the same on the new board?
Comment by Max Levine on September 20, 2010 at 5:06am
OK, thanks Jani and Chris.
Admin
Comment by Morli on September 20, 2010 at 12:36pm
Jeffery , I think it was answered to death since its birth. Like every one else I too wish that it was cheaper ( ?!! ) but now that it is shown that it can't be done any cheaper . Price is 160$ unless I missed a updated price announcement somewhere. Cheers
Comment by Jordi Muñoz on September 20, 2010 at 12:45pm
The price increase is due to the lack of the AT45DB161D-SU. It normally cost $2-3 dlls, but companies are ripping people off with prices up to 21 dlls each... By the middle of 2011 the shortage may end and the prices will be lowered.
Comment
