[UPDATE: This project is now being ported to a proper Google Code repository and manual. For instructions, start there. You can also join the ArduRover User Group here.]
Hello to ALL, the new firmware for APMRover v2 has been tested successfully on my rover on may 1st, 2012 on full autonomous reco mission following a navigation plan. This new release of the APMRover v2 works on the APM v1.4 with the OilPan shield (magnetometer + MT3329 GPS) and also of course on the APM v2. The previous version of the APMRover v1.0 was a light size version specially designed for the APM1280 CPU (only) board and the MT3329 GPS.
3689454489?profile=original
For the frame, I have used a Traxxas Monster Jam Grinder with a brushed and high power motor Titan 12T and its XL-5 ESC.
The APMrover UGV is able to run itself following a list of recorded waypoints. The waypoints list (FPL) can be preloaded with the APM Mission Planner OR better in live, recorded by the pilot himself (with the SW7) during a manual run and then replayed in a full autonomous mission.
3689454514?profile=original
3689454602?profile=original
3689454577?profile=original
3689454598?profile=original
The firmware APMrover2 for APM v1 + OilPan or APM v2 successfully tested can be downloaded HERE
The APMrover v2 is also online on the official ArduPilot-Mega GIT repository HERE
Below the PID setup for the APMrover v1 and v2:
3689454536?profile=original
The light firmware APMrover1 for APM v1 (CPU 1280 or 2560) that I have tested can be downloaded HERE
Here's how to connect your cables:
3689454662?profile=original
More infos at: http://diydrones.com/profile/JeanLouisNaudin
Have Fun and Enjoy with the APMrover...
Regards, Jean-Louis
  • Hi,
    I just realized that this project uses R/C servos for steering, and ESC (fwd/rev?) for the drive motor.  My old truck frame has neither!  I can probably swap out the simple DC steering motor; but what's a
    good ESC to use?
    Nikko Hummer H2
    Thanks!
    Alan Marconett
  • Hello Jean Louis,
    Just found this project, after following Ardupilot for heli for a while.  I would like to use an Arduino Mega and a 9DOF Razor IMU (SparkFun)
    9DOF IMU
    Along with a 66 Channel LS20031 GPS 5Hz Receiver, also from SparkFun Electronics.
    I expect the GPS won't matter much, and it does have an HC5883, so should be similar.
    Thoughts?
    Possible?
    Maybe I can make the changes; I haven't studied the code yet.
    Thanks for great project!
    Alan Marconett
  • Hello Jean-Louis,
    I've made tests with last version, but the situation isn't changed.
    With slewrate=1 the car go backwards for 4 meters and after very very slowly become to go forwards, if you rise the value, the proportion is: less distance backwards, more fast start forwards.
    Until now we haven't find the problem.
    I try to think this night!!!
    regards
    Franco
    with value of 2 the s
    Hello Robert,
    Good news about the update of Mission Planner by Michael Oborne, I shall soon test it with the Xbee telemetry on my rover.
    Jean-Louis
  • JL, it appears that Michael Oborne has made the change to Mission Planner, and it should now recognize us at ArduRover!!!  :)
    I haven't tested it yet.  I'm not sure how we even know which environment we get?  The pick-box is gone, seems it's auto-detect now.
    Anyway, if it works, that's great, we can continue to evolve the code in Trunk and make it our own.
  • Hello Jean Louis,
    now I try to change the serial port3 boudrate,
    after I report you, but the strange is that the problem of start in auto mode, rover has it also without apm planner.
    Anyhow I try and after I report you.
    regards
    Franco
    Hello Franco,
    It seems that Daniel Chapelat has got the same problem, and he has found the solution, see the previous posts.
    Regards, Jean-Louis
  • Jean-Louis,
    if it may help you, in mission planner with 2.1.3a, there are not the radio levels, the green one, and when I switch to auto, the voice said " no signal for......."
    I've try to upload rev 2.1.2 and evrything are ok!!!!
    Regards
    Franco
  • Hello Jean-Louis,
    I'think it is not due to mavlink libraries, becouse now I've try without mission planner, and is the same...
    When I start from manual to stabilized, rover make a little jump but after is stopped, and if I switch from stabilized to auto, rover is like DIED!!!!!!
    I think there is a software problem
    Any Idea?
    Regards
    Franco
  • I am getting ready to try your latest version on my big tank. I will let you know how it goes. My control esc is an m3 dual motor proportional control with the DIG function.
    Earl
