Arducopter 2.0 Beta first release!
3689405696?profile=originalMark Grennan
We're finally comfortable enough with Arducopter 2.0 to release it as a beta!
AC2 is a complete system for a range of Multi-Copters. It started out as a side project for me and turned into an obsession. Oh Well! Copters turned out to be even more addicting than I ever thought.
AC2 doesn't bring over any code from NG, but I tried to make the transition fairly easy. It should fly virtually the same and the default PID values are equivalent.
I think it's pretty close and fairly bug free, but I know there are a few left and that's why we need the community to help us find them and submit patches that improve performance. If you have an issue or something to contribute, please use the Google Code Issues list for prompt responses. I won't be tracking bug related comments in this thread. If you can, please include a log file from you flight with an indication how many seconds in you had a problem.
Google Code issues list
And one last note before we talk features: Safety first! Don't load this and expect it to work exactly like NG or that it will work out of the box with no issues. Don't calibrate your ESCs with the props on. Don't turn off your radio while it is armed. Test in your hand before adding props. Test in your hand after adding props. Always be prepared to put it back into stabilize in case an Auto mission behaves unpredictably. etc... Simple stuff, but you are in control and take the responsibility of flying when you load this code.
Now that's out of the way: Download here [UPDATE: The Mission Planner now supports direct AC2 firmware uploading, so please use it to get the code instead. No need for Arduino or compile source code anymore! That said, if you want to fiddle with the code, you can always get it here and use Arduino as usual.]
The full ArduCopter 2 Manual is here. Please read it before using the code!
What's New:
Simple mode allows the user to save the orientation of the copter while arming the motors. This means the copter can yaw in any direction and the sticks will reference the original orientation. Great for learning or  - emergencies in the air.
Position Hold is now called Loiter to be compliant with Mavlink Ground control stations.
RTL will fly the copter home and hold the position
Auto will fly a mission stored in EEPROM.
Copters supported:
+, x, tri, hexa+, hexax, y6
AutoPilot commands supported:
MAV_CMD_NAV_TAKEOFF   - Copter will takeoff and rise to a defined altitude.
MAV_CMD_NAV_WAYPOINT - Copter will navigate towards a waypoint. (Beta 1 disabled options: altitude minimum, time delay)
MAV_CMD_NAV_LAND - Copter will immediately go into Loiter (position_hold) and begin a controlled decent.  Mission scripting ends after this command.
MAV_CMD_NAV_LOITER_UNLIM - Copter will Loiter at current location.  Mission scripting ends after this command.
MAV_CMD_NAV_LOITER_TIME - Copter will Loiter for N seconds. (disabled for this version)
MAV_CMD_NAV_RETURN_TO_LAUNCH - Copter will return to Launch (home position)
MAV_CMD_CONDITION_DELAY - will delay the execution of next conditional command
MAV_CMD_CONDITION_DISTANCE - will delay the execution of next conditional command until the copter is within a minimum distance to next waypoint
MAV_CMD_CONDITION_CHANGE_ALT - will send copter to desired altitude, overrides next waypoint altitude.
MAV_CMD_CONDITION_YAW - controls how the copter will yaw. Angle (relative or absolute), speed, and direction are inputs.
MAV_CMD_DO_JUMP - sets the next waypoint to the desired index - for conditional loops
MAV_CMD_DO_SET_HOME - changes the home location
MAV_CMD_DO_SET_SERVO - outputs servo channel number to desired PWM
MAV_CMD_DO_SET_RELAY - sets the relay to postion 1 or 2
MAV_CMD_DO_REPEAT_SERVO  - toggles servos
MAV_CMD_DO_REPEAT_RELAY - toggles the relay
In flight tuning:
You can tune aspects of flight with your channel 6 flaps knob. To enable this, you need to compile and update AC2 directly with Arduino.
See AP_Config for options.
How to setup your radio:
ch1 = roll
ch2 = pitch
ch3 = throttle
ch4 = yaw
ch5 = mode switch - use your 3 position switch
ch6 = used for in-air tuning - not currently active, see AP_config.h for options
ch7 = use to set throttle hold value while hovering (quick toggle) - default position should be a low PWM value!
ch8 = NOT used!!! - this is the hardware manual - it's dangerous to use for quads BEWARE!!!
How to use the CLI:
You must go through each item and set the values to match your hardware
"setup" menu:
erase - when installing AC2 for the first time, run this to erases bad values from EEPROMS – just in case
reset - Performs factory reset and initialization of EEPROM values
radio - records the limits of ALL radio channels - very important!!!
pid - restores default PID values - only needed if you have changed them in flight with CGS, not for setup.
frame - sets your frame config: [x, +, tri, hexax, hexa+, y6]
motors - interactive setup of your motors, (X, +, or tri supported) Point your stick towards the motor to make it spin, throttle is passthough.
level - sets initial value of accelerometers - hold copter level, don't move it.
modes - sets the flight modes assigned to each switch position (you have 6 available), toggle roll to change, enter to save.
current - enables an Attopilot current sensor: [on, off, milliamp hours]
compass - enables the compass [on, off]
declination - sets your local declination value – lookup online for accuracy [decimal degrees!]
sonar - Sonar hooks to the "pitot" port which is an analog input [on, off]
show - a formatted output of all the settings
"test" menu:
pwm - outputs the pwm values of all 8 radio channels
radio - outputs the control values of all 8 radio channels in degrees * 100 or other value (see radio.pde)
gps - outputs GPS data
rawgps - outputs raw, unparsed GPS data
adc - outputs raw adc values
imu - outputs euler angles
battery - outputs voltage readings to analog in 0-3
current - outputs voltage and current from an AttoPilot current sensor
relay - toggles the relay
sonar - outputs sonar data in cm
waypoints - dumps stored waypoint commands
airpressure - raw output of absolute presure sensor
compass - outputs compass angles in degrees (0 = north)
xbee - outputs an XBEE sequence used for range testing
mission - writes a default mission to EEPROM [null, 'wp']
- choosing 'wp' option will send the copter 15 meters North and back again.
eedump - raw output of bytes in eeprom
"logs" Menu:
See the APM wiki to better understand how to dump logs and how to set the types of data you want to record.
AC2 Flight modes:
All of the modes allow the user to control the copter with the normal controls. You can get yourself out of a jam sometimes by simply nudging the copter while in AUTO or LOITER modes.
Options include:
ACRO - rate control only. not for beginners
STABILIZE - copter will hold -45 to 45° angle, throttle is manual.
SIMPLE - Remembers the orientation of the copter when arming, allowing the user to fly more intuitivey. Manual Throttle.
ALT_HOLD - Altitude is controlled by the throttle lever. Middle is hold, high = rise, low = fall.
LOITER  - When selected, it will hold the current altitude, position and yaw. Yaw is user controllable. roll and pitch can be overridden temporarily with the radio. Altitude is controlled by the throttle lever. Middle is hold, high = rise, low = fall.
RTL  - Will try and fly back to home at the current altitude.
AUTO  - Will fly the mission loaded by the Waypoint writer
GCS_AUTO - Not implemented
Special notes:
The props will NOT spin in stabilize when throttle is in the off position, even when armed.
Arming is Yaw right for 1 sec, disarm is yaw left for 1 sec. Just give it some juice to confirm arming.
Auto modes will NOT engage until the throttle is above neutral. So if you put the control switch to positio hold while it's on the ground, it will no spin up. Or at leat it shouldn't ;)
Good luck,
Jason
    That is correct and that is our goal in whole ArduCopter team and its development. ArduCopter 2 beta 1 is our first release of the ArduCopter software under our ArduPilot Mega code bases. Yes there are many things still to do and it will take some time until everything is done in as easy way as possible.
  • Ok,
    my mag orientation is comp up and pins back
    I want to use xbee at 115200
    If I use the planner none of these can be set.
    So I have to use arduino.
    Mees, the thing is that we are trying to get rid of all hardware configurations and just provide ready compiled HEX file to users. Users who want to tweak can still compile their own programs.
    You can use these ready made HEX files already in Mission planner and upload it from there.
  • The planner is very good and the software loads without a problem. Great Job.
    However, there are a lot of setting like mag orientation, telemetry, ... that can't be changed. To someone without any previous knowledge its like looking for a needle in .....
    In this topic a lot of people say, "oh, just add this line to the APM config and it will work." But I think its not that simple. I managed to open the config reference and ther are a lot of parameters to be changed. But a warning says, "don't copy/paste this into a new config, just add he lines you need". Thats the big problem. What line should be added? Just the "define" lines or more??
    I propose that if you want to keep it simple, a lot more setting should be integrated into the planner. This way, arduino should be obslete thus no problems compiling.
    An other solution is working with a config generator like the ardupirates one
    http://ardupirates.net/config/APNG_Config.php
    Don't get me wrong, these are not remarks saying that its all bad. Just some constats that could inprove the "dummy proofness" of the software.
    Thanks to everyone you is making this possible. Great job.
    I think I found a bug that cause Magellan's issue. Code is uploaded.
  •    Since Xbee is used so much, maybe there should be something added in the missionplanner AC2 setup to make it  easier to change or toggle Xbee connections.  This would help us away from the ArduinoIDE so much
    ArduCopter Calibrations Part 2
    Enabling Magnetometer and Sonar
    Russell, correct. Don't use trims. If you need trims it means that your level calibration is incorrect.
  • @ John    So I should not use Tx trim buttons at all?
  • Hi Jason, just to enrich the discussion about the command authority, I've noted that if you're flying against wind for some time keeping the stick in some direction, it seems to take that position as the "center"and then you start to loose the command. If you release the stick slowly it will then "centralize" it again.
    If you release the stick quickly, the copter will move to the opposite direction as much as the command you was giving to keep it in the position.
    Hope I was clear in my explanation. It happens even if you're just fling in stable mode without changing modes.
    Cheers,
    Leonardo
