ArduCopter 3.2.1 released
Warning: there was a period of about 12 hours after this blog was first posted where an older version (AC3.1.2) replaced AC3.2.1 for APM2.  If you think you may have downloaded for the APM2 during these initial period, please check the version on your board by looking at the title bar of the Mission Planner (see the 5th comment from me below for a screenshot)
ArduCopter 3.2.1 has completed beta testing and has been released as the official version available through the mission planner and other ground stations.  If upgrading from AC3.2 there should be no need to re-do any configuration.
Changes from AC3.2 are listed below and in the ReleaseNotes:
1) Enhancements:
    a) reduced twitch when passing Spline waypoints
    b) Faster disarm after landing in Auto, Land, RTL
    c) Pixhawk LED turns green before arming only after GPS HDOP falls below 2.3 (only in flight modes requiring GPS)
2) Safety Features:
    a) Add desired descent rate check to reduce chance of false-positive on landing check
    b) improved MPU6k health monitoring and re-configuration in case of in-flight failure
    c) Rally point distance check reduced to 300m (reduces chance of RTL to far away forgotten Rally point)
    d) auto-disarm if vehicle is landed for 15seconds even in Auto, Guided, RTL, Circle
    e) fence breach while vehicle is landed causes vehicle to disarm (previously did RTL)
3) Bug Fixes:
    a) Check flight mode even when arming from GCS (previously it was possible to arm in RTL mode if arming was initiated from GCS)
    b) Send vehicle target destination in RTL, Guided (allows GCS to show where vehicle is flying to in these modes)
    c) PosHold wind compensation fix
    d) prevent infinite loop with do-jump commands pointing at each other
    e) pixhawk memory corruption fix when connecting via USB
    f) vehicle stops at fence's alt limit in Loiter, AltHold, PosHold (as it did in AC3.1.5)
    g) protect against multiple arming messages from GCS causing gyro calibratoin failure
Thanks very much to Marco and our beta testers who put their copters at risk over the past several weeks to help us iron out these issues.  Also Thanks to Raph for the video (this is actually a video from AC3.2).
  • Don't know, maybe your TRIM_THROTTLE is set to high at 607 instead of 475 or you have a bad mission.
    Throttle out goes to minimum when you set it to Auto.  Need to have logging set higher so we can see more data.
  • hi
    I almost had three crash's about a month ago and still cant figure it out
    They all happen as soon as I engage AUTO mode, the quad droped altitude very fast (if i'm not mistaken the motors turned off) and I had to switch to stabilize and apply full throttle to recover it, one of the first times it actually touched the water when it recovered.
    I cant understand what did really happened, why did it fall like a rock when AUTO was engaged ?
    the mission was initially planned with mission planner, and in the second time I tried tower, but gave me the same result.
    The last time it goes to AUTO I can understand that the problem can be related to the high hdop and the quad tried to hit a wall, luckily I switched to PosHold and recovered in the last second!
    Log here: https://www.dropbox.com/s/gh46sryiv0iuvt5/2015-07-27%2021-25-53.bin...
    Dropbox - Error
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
  • Is like your baro alt diverge with alt, for vibration consecuences, vibs affect baro; you have to see what the reason for that suddenly vibration, like a mechanical problem
    3702025318?profile=original
  • Perhaps you have your fence programmed to 100 mts? and your copter reaches it and try RTL because you have fence failsafe enabled, check that
    3702025348?profile=original
    @Vusal,
    The compiled binaries for all the different frames can be found here.  Generally people use the mission planner (or other GCS) to upload to their boards though.
    I am trying to use a LidarLite sensor from PulsedLight, but don't manage to set it up.
    Maybe somebody can help?
    Here is my issue: http://diydrones.com/forum/topics/lidarlite-working-correctly?xg_so...
  • woo it will be a big release
  • Here is a scenario with 3.2.1 that can be surprising:
    1.) Disable Radio Failsafe (FS_THR_ENABLE=0) so that a ground station can ARM the copter without the radio
    1.) Turn on radio and increase throttle to half way with the copter turned on
    2.) Turn off the radio
    3.) Arm the copter with the ground station (Mission Planner or whatever you'd like) in stabilize mode
    4.) The copter's motors will be at half throttle (or whatever the throttle position was used before the R/C was turned off.)
    I had my copter anchored to the ground for testing purposes so nothing bad happened. If I override the throttle using RC OVERRIDE on channel 3, the behavior is normal. But, if I release the override with the R/C turned off, the throttle will revert back to the last used R/C radio throttle setting.
    I would think the RC override would reset the default value.
    If I could detect whether the R/C was on using MAVLINK messages, I could go ahead and leave the RC OVERRIDE for throttle at least turned on, but I haven't seen a message that provides a reliable way to do that. The RSSI values for the RC related messages are all 0 and the PWM values for the RC channels are all set to the values corresponding to the last time the R/C was turned on. Is there a reliable way via MAVLINK to detect whether the R/C is turned on?
    I know this is an edge condition, but it can be very surprising behavior if you're not ready for it.
    (I saw some similar behavior in the motor test functions as well where the throttle got pegged for a given motor even though I had specified a low throttle value.)
  • I get twice the same ID on Compass_dev_id and Compass_dev_id2. so AC 3.2.1 see that there are two of them but gives the same ID and so I get a prearm compass not kalibrated.
    Two days ago everything was fine an I could perfectly fly in Loiter.
    I didn't touched the copter since then, pluged the usb to my AUAV-X2 and then compass error (preArm Compass not Calibrated)
    My compass is the one frome drotek the XL M8N - HMC5983.
    Values before having problems
    Compass_autodetec: 1
    Compass_dev_id: 73225
    Compass_dev_id2: 131594
    Compass_external: 1
    Compass_mottc: 1
    Compass_ofs_x:-22
    Compass_ofs_y:-32
    Compass_ofs_z: 38
    Compass_ofs2_x: 76
    Compass_ofs2_y: -200
    Compass_ofs2_z: -66
    Compass_use: 1
    One day after only with usb connected to mission planner
    Compass_dev_id: 131594
    Compass_external: 0
    Compass_mottc: 1
    Compass_ofs_x:-22
    Compass_ofs_y:-32
    Compass_ofs_z: 38
    Compass_ofs2_x: 76
    Compass_ofs2_z: -66
    Compass_use: 1
    Please tel me where is the bug.
  • I don't know why but in this post I don't have upload files, I don't know if others can do it.
