ArduCopter 3.2 ready for wider use
After months of testing, ArduCopter 3.2 (aka APM:Copter) is ready for widespread use and we invite all users to give it a try.  In order to manage the support load at first it will be available only through the Mission Planner and APM Planner2's Beta Firmwares link.  This link is visible from the regular "Install Firmware" page if you check the "Advanced View" on the Config/Tuning >> Planner page.  On APM Planner2 the "Advanced View" it is under the File menu.
In about two weeks we plan to replace AC3.1.5 with AC3.2 as the default version dispensed by the ground stations.
The full list of changes can be found in the ReleaseNotes but here are the highlights:
Flight Mode Enhancements:
  • PosHold flight mode: similar to Loiter but with direct response to pilot input during repositioning
  • ACRO mode handling improvement EXPO (for faster rotations)
  • Drift mode uses "throttle assist" (similar to AltHold)
  • Smoother transitions between flight modes (i..e when entering Loiter or RTL from high speeds)
Mission Enhancements/Fixes:
New Sensors/Devices:
Safety Features:
  • EKF/DCM check will switch to LAND mode if heading error > 60deg for 1 second
  • Baro glitch detection
  • Pre-arm check for Gyro calibration success
  • Pre-arm check that internal & external sensors (gyros, accels and compass) are consistent (Pixhawk only)
  • Parachute support (Pixhawk only)
  • Feedback to Pilot when taking off in AltHold, Loiter, PosHold (i.e. motors spin up a little as throttle is raised)
  • EKF (new attitude and position estimate system only used for reference in this release)
Bug Fixes:
  • Pixhawk GPS driver buffer overflow that could lead to missed GPS messages
  • Pixhawk I2C bug that could lead freeze up if I2C bus is noisy
Known issues/Warnings:
  • Pixhawk users will need to recalibrate their compasses
  • PosHold won't show up as option on FlightMode screen if you have an old version of mission planner.  Please select Help > Check for Updates
  • Landing detector is more strict meaning it may take longer to disarm after RTL, AUTO
  • Set THR_MID parameter especially if you have a very powerful copter because "Feedback to Pilot" raises throttle to 1/2 of THR_MID
  • Spline twitches slightly as it passes a waypoint especially if WPNAV_SPEED is set > 500.
  • Dropped support for NMEA and SIRF GPS on APM boards (ran out of Flash space)
  • Dropped ssupport for sonar for MultiCopters on APM1 and TradHeli on APM1 & APM2 (ran out of Flash space)
If you hit issues, please post them in the APM Forum and include a dataflash log file if possible.
Special thanks the Marco and the Beta Testing team from the AC3.2 beta testing thread who put their copters at risk in the pursuit of a smooth, safe release.  Here are links to some of their videos: Marco's DJIs900, Holger's Water Tower, Josh's Acro, Ray's TradHeli2&FPV, Raph's Hawaii, PhillS's CommandYawThor's Zombie Run&FollowMePhanivyas's Test, Rob's TradHeli, Christian's Test1&Test2Balloon's Spline, JimJ's FPV, Ultrojo's ROI & Spline&FollowMe1&FollowMe2, Troy's Mission
Thanks also to the code contributors to this release including Tridge, Jonathan, Leonard, RobL, Paul Riseborough, MichaelO, Julien Dubois, David Dewey, Andrew Chapman, Emile, Allyson and many more.  If you want to get involved check-out our dev wiki.
    @Gary,
    Yes it is the same as 3.2 RC14.
    If you already have that release candidate loaded then no need to load the firmware again.
    Nathaniel ~KD2DEY
    Nice job Team!
  • Nice job devs and testers.  Thanks for giving us such amazing firmware.
  • Great news! I really like the list of new available sensors!
  • Hi Randy, and Dev Team,
    Congratulations on getting this huge upgrade out.
    From what I understand, this is the same as Beta 3.2 RC 14,
    if this is the case, do those of us running that gain any thing by updating to new Beta 3.2 or should we just leave it at RC 14 for now?
    Best,
    Gary
  • Congats to all!
    This is a real major update that will put APM:Copter at the top of the list!
  • I love 3.2 :)
  • Alright!!! Nice work Randy and the Dev Team!
    Randy, Does this include "Follow me" mode like the one in the Iris+?
    Droidplanner 2 has brought back the follow me feature on it's latest release,
    Thanks Randy!
  • Good improvements. Keep up the great work.
  • You guys are the absolute best. AC 3.2 is so full of awesomeness that it is going to take some time to get my head around all that you've done (that I will be likely to use). The high quality work done by the Developer and Test teams are a unparalleled display of international community spirit and collaboration.
    Hats off to you guys (and girls) for a splendid delivery. You all rock.
