ArduCopter 3.2 ready for wider use
After months of testing, ArduCopter 3.2 (aka APM:Copter) is ready for widespread use and we invite all users to give it a try.  In order to manage the support load at first it will be available only through the Mission Planner and APM Planner2's Beta Firmwares link.  This link is visible from the regular "Install Firmware" page if you check the "Advanced View" on the Config/Tuning >> Planner page.  On APM Planner2 the "Advanced View" it is under the File menu.
In about two weeks we plan to replace AC3.1.5 with AC3.2 as the default version dispensed by the ground stations.
The full list of changes can be found in the ReleaseNotes but here are the highlights:
Flight Mode Enhancements:
  • PosHold flight mode: similar to Loiter but with direct response to pilot input during repositioning
  • ACRO mode handling improvement EXPO (for faster rotations)
  • Drift mode uses "throttle assist" (similar to AltHold)
  • Smoother transitions between flight modes (i..e when entering Loiter or RTL from high speeds)
Mission Enhancements/Fixes:
New Sensors/Devices:
Safety Features:
  • EKF/DCM check will switch to LAND mode if heading error > 60deg for 1 second
  • Baro glitch detection
  • Pre-arm check for Gyro calibration success
  • Pre-arm check that internal & external sensors (gyros, accels and compass) are consistent (Pixhawk only)
  • Parachute support (Pixhawk only)
  • Feedback to Pilot when taking off in AltHold, Loiter, PosHold (i.e. motors spin up a little as throttle is raised)
  • EKF (new attitude and position estimate system only used for reference in this release)
Bug Fixes:
  • Pixhawk GPS driver buffer overflow that could lead to missed GPS messages
  • Pixhawk I2C bug that could lead freeze up if I2C bus is noisy
Known issues/Warnings:
  • Pixhawk users will need to recalibrate their compasses
  • PosHold won't show up as option on FlightMode screen if you have an old version of mission planner.  Please select Help > Check for Updates
  • Landing detector is more strict meaning it may take longer to disarm after RTL, AUTO
  • Set THR_MID parameter especially if you have a very powerful copter because "Feedback to Pilot" raises throttle to 1/2 of THR_MID
  • Spline twitches slightly as it passes a waypoint especially if WPNAV_SPEED is set > 500.
  • Dropped support for NMEA and SIRF GPS on APM boards (ran out of Flash space)
  • Dropped ssupport for sonar for MultiCopters on APM1 and TradHeli on APM1 & APM2 (ran out of Flash space)
If you hit issues, please post them in the APM Forum and include a dataflash log file if possible.
Special thanks the Marco and the Beta Testing team from the AC3.2 beta testing thread who put their copters at risk in the pursuit of a smooth, safe release.  Here are links to some of their videos: Marco's DJIs900, Holger's Water Tower, Josh's Acro, Ray's TradHeli2&FPV, Raph's Hawaii, PhillS's CommandYaw,  Thor's Zombie Run&FollowMe, Phanivyas's Test, Rob's TradHeli, Christian's Test1&Test2, Balloon's Spline, JimJ's FPV, Ultrojo's ROI & Spline&FollowMe1&FollowMe2, Troy's Mission
Thanks also to the code contributors to this release including Tridge, Jonathan, Leonard, RobL, Paul Riseborough, MichaelO, Julien Dubois, David Dewey, Andrew Chapman, Emile, Allyson and many more.  If you want to get involved check-out our dev wiki.
  • I had flown my quad with AC3.2-rc14 with APM2.6. on the second waypoint the aircraft got stuck. i gave RTL but it did not respond. finally i flew the aircraft manually to a safe landing. exactly same thing happened on a other aircraft that had AC3.2-rc14 with Pixhawk that also got stuck on the second waypoint and did not take RTL command. but after doing RTL couple of times it finally returned. somehow i do not have the logs for both of them. this has never happened before i upgraded to AC3.2-rc14 version. the auto missions have always been very accurate and reliable.
  • Thanks Winston.
  • Hi Denny Rowland! APM Planner for mac not perform the calibration of the two compasses in AC3,2, at least not for now, you have to do with Mission Planner (windows OS) in its latest beta versions.
  • Hi Guys
    I have flashed 3.2 Beta from APM Planner2 (Mac) several times now but I always end up with this same message after completing compass calib.    "pre arm check - Compass not calibrated"
    The typical values I see are x=32.959  y= 33.959  z= 212.588. (These seem to work OK with 3.1.5)
    I have tried a different compass with the same result and have run out of ideas now.
    After a 3 year hiatus, due to over indulgence in that Chinese stuff, I seem to have lost my way a bit with APM.
    Guess I must be doing something wrong....
  • Thanks Alex, Good advice.
    Jim,
    Follow the directions here in the wiki.
    Nathaniel ~KD2DEY
    @HZL.  You can modify this cable to work with the Pixhawk https://store.3drobotics.com/products/telemetry-slash-osd-y-cable-a... but 3DR does not make one purpose built for the Pixhawk.
  • @CraigElder..
    Whoops again.. timing and race issues have it working unreliably... ah Crag.. have you got a part  number/3DR store URL for a PIXHAWK/MiniOSD 1.1 compatible splitter cable?
         thanx in advance
          hzl
  • @Denny, I beg to differ.  This release just blows 3.1.5 out of the water.  The smooth response of the new flight modes and additional features including follow me is just so impressive.
    We've had our test platform in 35+ kph winds yesterday and everything went without a hitch including about a dozen planned missions using the ROI for camera control and it was really incredible to see it all work over and over again.
    Again, a big thank you to the dev team for pulling this off !  We'll be posting some of our footage soon and will provide a link to it.
  • I don't think this is quite ready for release yet!
