I just got finished my octocopter with Arducopter electronics. It is built to carry DSLR and should fly 7-8 minutes with 1000g payload. Copter is actually just a quad which has two ESCs and motors on each end. It proved to be really stable platform on first tests last weekend.
I fly with 5000 mAh 14.8V Lipos and have eight 750kv/100W motors. Still the flight time with such a heavy camera will be short. But actually from previous experience I know 5 minutes is long enough for photographing a target. After that you can land, change battery and make a plan for next 5 minute flight.
Images of my build can be found:
http://www.markusjahn.net/gallery2/main.php?g2_itemId=45850
and first flights:
http://www.markusjahn.net/gallery2/main.php?g2_itemId=45735
Youtube -video shot from another Oktokopter:
https://www.youtube.com/watch?v=viEoOtErBnU
Hashcopter feels like it is going to stick as a name for this one. :-)
Square tube used is 15mm x 15mm with 1mm wall thickness. I think when putting wires and bolts through tubing the extra room is really needed. When comparing the weight of 10mm or 15mm tubing it is almost insignificant as most of the weight comes from motors, ESCs, wiring and battery anyway.
Bars are 80cm long and motors are bolted straight through the top part of the tube(big holes below to get the screws through) with two screws.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dindustria...
I doubt 0.5mm wall tubing can resist to such load and forces.
Will use 10*10mm 1mm wall and it is the minimum I could think for this task.
Markus, what is the length of the bars ?
APM is connected to ESCs with a Y-cable. If one motor or ESC fails it shouldn't cause any trouble to others functionality. I will have to test if the Octo still stays airborne. In theory it should survive a motor failure.
One thing that is also part of the design is that all four beams/bar/whatever are detachable quite easily. This should help repairing them after crashes because I don't have take everything to pieces. Also the center piece which contains APM+IMU, GPS and receiver can be taken easily to table for repairs/troubleshooting.
After flying about an hour with the copter I can say it is comparable to the Mikrokopter Okto which costs five times the price of this one. And if you want officially use their copter for commercial purposes you will have to pay extra 600 euros for that too.
I think it would fly nicely with 3-cell batteries. But you should then buy higher kv motors to keep the power level the same.
Looks like a strong structure doing the frame like that. I posted about doing an octo like this. Nobody had a reason why it wouldn't work, while we wait for I2C support so it's good to see it's working.
Do you think it would do ok with 5000mAh 3S?
1
2
of 2 Next
