I will maintain the code for a while in a repository at http://code.google.com/p/ardu-imu-pilot/
If you try it out give me your feedback. It is similar to ArduPilot 2.4 but uses a different header file.
To interface ArduIMU to ArduPilot you connect the gps (ublox only) to ArduIMU, provide common power and ground to ArduPilot and ArduIMU, and connect the serial output pin of ArduIMU to the serial input pin of ArduPilot.
I'm new at this wonderful world,
I'm trying to run run Ardupilot + arduimu + xbee pro 2.4
So in addition to the above connections, I also have the xbee modules configured for 38400 and connected gnd, 5v , xbee rx pin to ardupilot shield -ve,5v, out pin (5th from gps connector)
I get gps fix (solid blue led on the imu) but the ground station displays nothing, also the xbee seems to emit nothing (terminal program showed nothing)
I only connect the xbee module to the ardupilot after about 30 sec of the powerup.
The same set of xbee(s) I'm using for paparazzi, the only change I did was to change the baud rate to be 38400.
Can anyone help?
Thanks.
Wiring between Ardupilot and Arduimu.
Wiring configuration for GPS Ublox5 with cable FTDI.
Thank you.
As a note, I am not developing this firmware any longer as I am working to incorporate the good stuff here into the ArduPilot 2.5.1. That may be released this month with any luck.
And congratulations again for the code.
2
3
4
5
6
of 8 Next
