What's changed:
I've included a folder for connecting your ardupilot hardware to X-Plane. There are PNG files showing the configurations to make in the menus.
X-Plane supplies IMU data and airspeed data to Ardupilot so you must select the GPS_IMU option to connect.
New altitude estimation - Thanks to Ryan Beall for this one. This smooths out noisy altitude readings from GPS.
Takeoff and landing are now full features. Their use has been simplified and are assigned full flight modes which can be seen with a ground station.
New Fly by wire throttle command by Christof Schimd.
Updates altitude hold for those with airspeed sensors. Airspeed is now recorded in m/s instead of air pressure value. Since calibration for your particular pitot tube setup could be needed there is now a calibration value in the header file.
Improved stick mixing response for all modes.
Waypoints will be skipped if you miss them after one loop around. The number of degrees can be changed in the code so let me know how many is good.
Loiter hold has been improved.
Cross track gain now on by default.
Numerous bugs are gone.
Old, unused code and vars have been removed. Code has been reformatted and commented.
If you have any issues, please comment here and I'll get them fixed in the final release.
Jason
I have updated my HITL simulator app to support Xplanes and FlightGear, here are the files you need
http://vps.oborne.me/Ardupilot2Xplanes.exe
http://vps.oborne.me/ardupilot.xml - this file is the FG protocol - copy to C:\Program Files (x86)\FlightGear\data\Protocol
this version also creates KML files of the path flown, they are written on every mode change.. ie auto to manual, auto would be written to a kml.
Michael
Earl
Also what variable is SPD ?
You can see in fly by wire ATH is os
in next pic in auto mode the ATH is double the value.
I thought it would be the alt of the next waypoint.
Earl
What's the ATH indicator? BTW, I flew 2.7 today and made some fixes. It's flying very well now.
Absolute waypoints are the only type implemented. Don't bother trying to relative for now.
I've uploaded a new beta in the downloads section for testers to try.
Jason
Jason, is this a bug ?
Earl
It's not available as a zip for download. It's only available in the SVN repository here (http://ardupilot.googlecode.com/svn/branches/ArduPilot_2_7)
Nathaniel
See my reply to your other post here.
What do you mean "And where was only round moving on runway ... "??
Nathaniel
3
4
5
6
7
of 8 Next
