I know, i know. I'm the worse person in the world to write tutorials (and also to respond comments, emails and posts), but i promise i will do my best. Community I need your suggestions: do you prefer word documents that can be converted to PDF, with revisions, editions etc? Or only a simple post with images?
    Nick, you still have one, or two if you disable the battery voltage.
  • One quick question: How many analogue and digital pins are left spare after the MUX, servos, XYZ thermopiles and pressure sensor?
  • I think single updatable post is best with a "last updated" note.
    That way it's always here.
    Step by step construction images would go well with text and an explanation of all the new features would be cool too.
    thanks
    Matt
  • With the new "shield" installed, how and where do the sensors attach to? Where does the ESC control cable attach to? Any pics of the new setup with the corresponding servos, rx etc yet? Tnx!
    Hello Paul,
    I will convert them to PDF, the idea of word documents is to add and modify errors and when the document is ready convert it to PDF and publish it...
    Thanks !
    Thank you very much for your feedback!!!
    OK, i think i will start the draft with word document, and when i have something readable i will convert it to PDF. And also every time i add something new to the paper i will make a post.
  • I have to go with PDF.
    Many thanks,
    Dale
  • Either way is fine (pdf vs. post). Although I don't mind MS Word documents, this would be my least favorite option due to increased risk of viruses, etc. Actually from standpoint of "security" risk I would orderem them as :
    - post (least likely)
    -pdf (yes you can "catch" bad exploits and other bad stuff from pdf files)
    -MS Word
    Jordi .pdf files would work fine.
