BaroneOSD is a PAL video overlay impression WITHOUT additional hardware required (NO LM1881 Sync generator).
Use only 3 pin:
D1 (USART TX) used to pump pixel in the video connected with a 330Ohm resistor to D6
D6 (AIN0) Video in/out, connect here you camera or radio TX.
D7 (AIN1) 0.3V Voltage reference (you can use a partitor resistor)
http://www.elenafrancesco.org/arduino/
  • Neat stuff! What is the compiled code size and memory constraints?
  • Can u post a wiring diagram of how you connect it inline to a camera and Tx
  • So...did anyone get this to work yet? Would be nice to get some more information on this...
  • I'm near a new version, that use SPI port not USART, pin needed D11 MOSI, D6 D7 to use analog comparator (with only 2 resistor!!!).
    D11 (PB3) is not used.
    D6 (PD6) is "remove before flight"
    D7 (PD7) is GPS power switch
    How it is possible to use D6 D7?
    P.S. I have found a small error in the Hardware Diagram
  • It is not a big deal, you can cut the tracks of two pin and with small wires solder them on required pins on the microcontroller or. You can modify modyfy the pcb of Openlog, it is freely available for download.
    I have pasted the files here also;
    OpenLog.brdOpenLog.sch
  • To use the analog comparator, PD6 PD7 (AIN0 AIN1) are needed, but are not avaiable on this implementation sorry.
  • Yes, F. Ferrera, thats right !
    http://www.sparkfun.com/commerce/product_info.php?products_id=9530
  • Here is a standalone unit based on AVR, perhaps some of the info there would helpful in this? Its based on NTSC. The same guy has a HAM radio telemetry system as well.
    Tim
    The Videoverlay on garydion.com
    A page about amateur radio projects and others built using the Atmel atmega8 microprocessor.
  • Did you mean this ?
