    You can use Software.serial on other digital pins to get additional serial I/O. It's just not very efficient.
  • the problem is two way comunication then or? or is there some way to multiplex the serial port?
    Yes, we will be releasing the EasyStar version this week.
  • can u use the adrupilot in a easystar?
  • I got the answer and already made the adaptor !
  • Hi Chris and Jordi, today while attempting to program the Atmega168 i had the need to build an adaptor for my Avr programmer but then i couldn't do it because of the lack of info about what does each pin of the programming ports, couldn't find any info about it and i must confess i didn't look at the schematics, could you please indentify each one for both Avr's on the Ardupilot top board ?
    thanks
  • GPS just uses Rx, so sending anything out by serial works. Question is how do you connect it with mobile phone. If you do, you can record GPS locally or use GSM network to send telemetry.
  • I was just wondering if I could use Serial.println() to communicate with a cellphone to submit data to ground, or will this influence the GPS readings? Does the GPS only require Rx on the module so TX is free or?
  • Chris,
    Thanks..helpful. This radio purchase is my biggest stummbling block. Glad to hear the 72mhz radios work Ok. Also, I have the LS2003 on the carrier board, but the connector is not the same. I soldered a header to the board for use with a breadboard. Is there a schematic available that shows the connection between the GPS and the Ardupilot? Thanks...Win
  • i try upload the ardupilot code
    and show me, this error message
    25: error: ServoTimer1.h: No such file or directory In function 'void setup()':
    In function 'void altitudeHold()':
    In function 'void Steer()':
    i buy the board in sparkfun . Help!!!!
