  • what about Arducopter? Where can I buy it?
  • Thanks Chris...here is a quick comparison of standard/digital servos.
    http://www.futaba-rc.com/servos/digitalservos.pdf
    Basically a digital has a microprocessor in it to reduce the deadband but take more power. You typically find these on high precision controls like the rudder on a Heli (or the elevator on the Apprentice) for fine control. Yes mine plug directly into the Specktrum Rx, so should work with your board I take it.
    We've never tested ArduPilot with digital servos (in fact, we've never seen a digital servo!), but if they work with regular RC equipment, they should work with ArduPilot.
  • I am similar situation recent joinee with similar questions. I am also looking at working with one of the local schools for the UAV challenge in QLD Australia so any help or assistance would be appreciated
  • Just joined up! I fly RC Helis and planes and would like to get into UAVs. I have looked at you setup and it looks great. I have only worked with MicroChip PICs and use PicBasic Pro as well as assembly coding, so understand the workings of microprocessors, just not the one you use.
    I have an E Flight Apprentice trainer that might be a good candidate for the UAV (lots of payload). It has the Spektrum 2.4 GHz Tx/Rx. Have a 7 Channel Tx. It uses a Y Harness for the ailerons. It does have a digital servo for the elevators. Will your hardware support digital servos?
    I'm sure I will have more questions as I learn more.
    John
  • No only software change the current Ardupilot hardware stay the same.
  • Will there be any hardware changes with 2.0?
    I think the current MUX code should work. Have you tried it?
  • Hi I obtained and built 10 Beta 3 ardupilot boards could you email me, post or point me to the MUX code that was used in that version.
  • Thanks, I should have read the instructions closer. I soldered connectors to the board first instead of cutting extension cables. oops.
