ArduPilot (Legacy) main page
3689315381?profile=original
[This original ArduPilot board, now called the "Legacy ArduPilot" is no longer produced or officially supported by the DIY Drones dev team, and this page is maintained just for historic reasons. However, there are still many users of it out there and it still works fine. The user group for Legacy ArduPilot users, for both thermopile and IMU use, is here.]
ArduPilot is a full-featured autopilot based on the Arduino open-source hardware platform. It uses infrared (thermopile) sensors or an IMU for stabilization and GPS for navigation. It is the autopilot used to win the 2009 Sparkfun Autonomous Vehicle Competition.
The hardware is available from Sparkfun for $24.95. An expansion board ("Shield") kits that includes an airspeed sensor, a 3.3v power regulator for 3.3v GPS modules and other sensors and cables and connectors for easy attachment of the XY and Z sensors, is available from our own store for $57.20.
User f
ArduPilot features include:
  • Can be used for an autonomous aircraft, car or boat.
  • Built-in hardware failsafe that uses a separate circuit (multiplexer chip and ATTiny processor) to transfer control from the RC system to the autopilot and back again. Includes ability to reboot the main processor in mid-flight.
  • Multiple 3D waypoints (limited only by memory)
  • Altitude controlled with the elevator and throttle
  • Comes with a 6-pin GPS connector for the 4Hz uBlox5 or 1hz EM406 GPS modules.
  • Has six spare analog inputs (with ADC on each) and six spare digital input/outputs to add additional sensors
  • Supports addition of wireless modules for real-time telemetry
  • Based on a 16MhZ Atmega328 processor. Total onboard processing power aprox 24 MIPS.
  • Very small: 30mm x 47mm
  • Can be powered by either the RC receiver or a separate battery
  • Four RC-in channels (plus the autopilot on/off channel) can be processed by the autopilot. Autopilot can also control four channels out.
  • LEDs for power, failsafe (on/off), status and GPS (satellite lock).
Resources:
ArduPilot requires the free Arduino IDE to edit and upload the code to the ArduPilot board.
The code is currently optimized for the Mutiplex EasyStar three-channel powered glider and FMA sensors, but can be modified for other aircraft and sensors. It uses the rudder/ailerons and elevator to maintain level flight and navigate to GPS waypoints. It supports a desktop setup utility and ground station software. It also includes a "fly-by-wire" mode that simply stabilizes RC flight. The main code is ArduPilot2.x.zip in the download section of our Google Code repository, where x is the latest version.
What you need to make a fully-functional autopilot:
Open source extras:
  • If you want to build your own board from scratch, the necessary files and component lists are here.
  • [Note: you shouldn't need this, since this code is loaded on the ArduPilot board at the factory] Latest multiplexer code (for the board's second processor, an Attiny, which runs the failsafe system) is here.
    Instructions for loading this code are here.
Recommended UAV setup:
3689303688?profile=original
Airframe option one: Hobbico SuperStar (49" wingspan, $95, shown above). This is an inexpensive, good flying high-wing trainer with ailerons. It can be hand launched in a park or take off from a runway, and replacement parts are readily available in case of a crash. If you want much better performance with this aircraft, you can upgrade it to a brushless motor, speed controller and a LiPo battery. [If you don't already have one, you'll also need a balancing charger and power supply.] Note: any stable aircraft with both ailerons (for stabilization) and rudder (for navigation) can work, so feel free to experiment with what you've got.
3689313666?profile=original
Airframe option two (recommended for ArduPilot 2.x): EasyStar (shown above). Performance can be improved with the modifications described in this post.
You'll also need:
  • A six or seven channel RC transmitter and receiver, with at least one toggle switch (ideally three-position but two-position will work, too, although you will have to mix channels to have access to both autopilot modes in the air), such as the Futaba 7C.
  • Some servos (at least three for ArduPilot 1.0; at least two for ArduPilot 2.x) and at least three female-to-female servo cables to connect the RC receiver to ArduPilot.
Cool optional extras for your UAV:
  • Hi all, just wondering what is the unit for Max Speed and Max Altitude in the config tool. I changed the setting from feet to meters and they stay the same. Are they "meters/sec for speed" and "meters for altitude"?
  • Thanks Chris for the quick reply.
    I found out I forgot to solder on the jumper wire 5 min after I posted my "problem".
    I am so embarassed : )
    alanhsu, did you solder the jumper wire to channel 3, as instructed in the manual?
  • Thanks for the info Chris. One last silly question, will ArduPilot work on helis with FMA Co_Pilot II?
    Anton, yes, in "walkaround" mode ArduPilot will work with any stand-alone stabilization system. You'd just need everything mentioned in the ArduPilot tab above, minus the XYZ sensors (and shield, if you don't want it to maintain airspeed)
  • HI Guys. I'm fairly new to UAV's. Have some experinece on RC planes & heli's. Was wondering, what equipment would I need to put together UAV on my existing plane, running existing FMA CPD4 copilot?. Also, will ArduPilot work with FMA new Co-Pilot II system?
  • ok thank's chris...
    i guess it is a STK500 clone or the STK500 itself (no way to tell)
    so it should be compatible i guess?
    if that works how shoul i set the fuse again?
    Jeremy, if the programmer is AVRISP compatible, you can just use the Arduino IDE to reburn the bootloader, which will also set the fuses.
  • hello guys,
    i'm back on the project now and i would like to re program the atmega 368 to make sure the fuse are corrects...
    i just baught a programer in taiwan and now if some body could give me a link on how to do that that would be great!
    i cannot seem to find it on this web site (only old topic on at45 and 168)
    thank you in advance
    in the same time i'll check the manual ...
    regards
    jeremy
    Just a jumper wire to the unused fourth servo out pins.
