ArduPilot (Legacy) main page
3689315381?profile=original
[This original ArduPilot board, now called the "Legacy ArduPilot" is no longer produced or officially supported by the DIY Drones dev team, and this page is maintained just for historic reasons. However, there are still many users of it out there and it still works fine. The user group for Legacy ArduPilot users, for both thermopile and IMU use, is here.]
ArduPilot is a full-featured autopilot based on the Arduino open-source hardware platform. It uses infrared (thermopile) sensors or an IMU for stabilization and GPS for navigation. It is the autopilot used to win the 2009 Sparkfun Autonomous Vehicle Competition.
The hardware is available from Sparkfun for $24.95. An expansion board ("Shield") kits that includes an airspeed sensor, a 3.3v power regulator for 3.3v GPS modules and other sensors and cables and connectors for easy attachment of the XY and Z sensors, is available from our own store for $57.20.
User f
ArduPilot features include:
  • Can be used for an autonomous aircraft, car or boat.
  • Built-in hardware failsafe that uses a separate circuit (multiplexer chip and ATTiny processor) to transfer control from the RC system to the autopilot and back again. Includes ability to reboot the main processor in mid-flight.
  • Multiple 3D waypoints (limited only by memory)
  • Altitude controlled with the elevator and throttle
  • Comes with a 6-pin GPS connector for the 4Hz uBlox5 or 1hz EM406 GPS modules.
  • Has six spare analog inputs (with ADC on each) and six spare digital input/outputs to add additional sensors
  • Supports addition of wireless modules for real-time telemetry
  • Based on a 16MhZ Atmega328 processor. Total onboard processing power aprox 24 MIPS.
  • Very small: 30mm x 47mm
  • Can be powered by either the RC receiver or a separate battery
  • Four RC-in channels (plus the autopilot on/off channel) can be processed by the autopilot. Autopilot can also control four channels out.
  • LEDs for power, failsafe (on/off), status and GPS (satellite lock).
Resources:
ArduPilot requires the free Arduino IDE to edit and upload the code to the ArduPilot board.
The code is currently optimized for the Mutiplex EasyStar three-channel powered glider and FMA sensors, but can be modified for other aircraft and sensors. It uses the rudder/ailerons and elevator to maintain level flight and navigate to GPS waypoints. It supports a desktop setup utility and ground station software. It also includes a "fly-by-wire" mode that simply stabilizes RC flight. The main code is ArduPilot2.x.zip in the download section of our Google Code repository, where x is the latest version.
What you need to make a fully-functional autopilot:
Open source extras:
  • If you want to build your own board from scratch, the necessary files and component lists are here.
  • [Note: you shouldn't need this, since this code is loaded on the ArduPilot board at the factory] Latest multiplexer code (for the board's second processor, an Attiny, which runs the failsafe system) is here.
    Instructions for loading this code are here.
Recommended UAV setup:
3689303688?profile=original
Airframe option one: Hobbico SuperStar (49" wingspan, $95, shown above). This is an inexpensive, good flying high-wing trainer with ailerons. It can be hand launched in a park or take off from a runway, and replacement parts are readily available in case of a crash. If you want much better performance with this aircraft, you can upgrade it to a brushless motor, speed controller and a LiPo battery. [If you don't already have one, you'll also need a balancing charger and power supply.] Note: any stable aircraft with both ailerons (for stabilization) and rudder (for navigation) can work, so feel free to experiment with what you've got.
3689313666?profile=original
Airframe option two (recommended for ArduPilot 2.x): EasyStar (shown above). Performance can be improved with the modifications described in this post.
You'll also need:
  • A six or seven channel RC transmitter and receiver, with at least one toggle switch (ideally three-position but two-position will work, too, although you will have to mix channels to have access to both autopilot modes in the air), such as the Futaba 7C.
  • Some servos (at least three for ArduPilot 1.0; at least two for ArduPilot 2.x) and at least three female-to-female servo cables to connect the RC receiver to ArduPilot.
Cool optional extras for your UAV:
  • So, I can't use Ardupilot 2.5 code for this:
    "ArduPilot's vehicle (car or boat) mode can also be used for ground testing aircraft navigation or as a simple navigation-only autopilot for aircraft with a separate stabilization system to provide a full autopilot solution. It is enabled by setting "Walkaround mode" in the configuration settings."
    ¿True?
    Thanks.
    Walk-around mode has been removed. I don't think we really have the functionality to support FMA Copilot in 2.5 anymore. You may nee to work with an earlier version.
  • HI,
    I want to use Ardupilot without shield board and without IR sensors (I'm using FMA Copilot for stabilization). I'd like to use 2.5 version of de code, but, where is the WALK_AROUND mode in this versión?
    Thanks.
  • So the ardupilot does not catch the control signals coming from the radio controller (except for the control pin #5), and are wired directly to the output. Oh ok I see now looking from the diagram. I will recheck everything and fix any solder point that is needed. The uBlox GPS is working great. Installed it, got a lock with in seconds, reloaded the ardupilot code and did a few other random test and got a lock every single time. Even got a lock inside our metal building!
    Sounds to me like a soldering error. If it's not passing through the elevator in manual mode, the only explanation is electrical--that's not going through code at all.
  • That's my problem I do not have elevator control. It is setup as show in the diagram. I have throttle and ailerons control but no elevator control.
  • Can i use this sensors with the Ardupilot with Shild? Those are from RangeVideo.
  • Hi Aaron,
    Don't you need elevator control too?
    Check this diagram...
    CH1 - Aileron/Rudder
    CH2 - Elevator
    CH3 - Throttle
  • I am having an issue with the ArduPilot passing the RC control single to the servos. I have it setup as described in the manual. Ailerons are on channel 1, flaps on 2, and throttle on 3. Running the latest version out, 2.5_04, in the terminal it shows in MANUAL mode, Startup: Ground. Problem I have is that the flaps are not getting passed through channel 2 on the ArduPilot board, Ailerons and throttle are.. Any ideas?
    Still having problems getting a GPS lock, team decided to go with the uBlox GPS instead, hopefully better luck with that one. Just have to deal with the purchasing dept cause they can not seem to get our order right...
  • No, this battery is only for Ardupilot, so how long???
