ArduPlane home page
3689354430?profile=original
3689312509?profile=original
Convert any RC airplane into a fully-autonomous UAV!
Just add the APM 2 autopilot to any RC aircraft and it becomes a fully-programmable flying robot with a powerful ground station and Mission Planner.
Features include:
  • Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
  • Unlimited 3D GPS waypoints
  • Built-in camera control
  • Fully-scriptable missions
  • One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
  • Replay recorded missions and analyze all the data with a graphing interface
  • Supports two-way telemetry with Xbee wireless modules.
  • Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
  • Fly with a joystick or gamepad via your PC--no need for RC control!
  • Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
3689354391?profile=original
3689354242?profile=original
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
*  APM 2.5 autopilot with GPS ($179)
*  [Optional] Telemetry kit ($75).
3689354459?profile=original
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies!3689354440?profile=original (We're partial to the SkyFun delta wing (right) and
Bixlee 2   powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
  • Is it possible to alter the channel assignments for the APM 2.5 output.
    I am using PPM sum from a DragonLink and the channel assignment is JR versus the Futaba style the APM uses.
    I could bypass the PPM sum and directly connect them but I was hoping for less wires. :-)
    Ife: Good catch. Fixed!
  • joe 4 channels plane ail. rud. thr. elv. 1 channel flight modes hope that helps
  • Is there a document that explains the ARDUPLANE source code. If you have any, I would appreciate it. Thank you !
  • Ok here is a weird one. On long tracks between waypoints greater than 64km apart, approx every 5 minutes the autopilot goes offline resulting in a hard dive, random roll, and throttle to idle. It recovers in 1-2 seconds, stabilizes the aircraft, and continues on course. Why?
    Also, is there any way to raise the limit of 127 for loiter radius and waypoint detection radius. At 65m/s with 45 deg bank maximum turn rate the minimum radius is 450m. This is way above the maximum setting of 127.
    Also, is there any way to add a divide factor based on air (or ground) speed to the roll and pitch PIDs, particularly P? Settings that work at 50m/s are to sensitive at 100m/s, etc.
    thanks
  • Thank you for all the quick responses...
    Like I said, I am evaluating several different systems APM just being one of them. The open source model is preferred so we have access to the source code for changes, at least at this point.
    Comments on comments:
    1. PID reaction does not react fast enough to handle the trim changes required. For example, landing gear extension results in a strong pitch down motion, and generally at low altitude. By the time it is compensated for, the aircraft crashes. When the gear is retracted, opposite occurs resulting in an uncommanded 2-3000ft climb. Any settings that compensate for this are two sensitive for maintaining level flight...Also, as fuel burns off trim changes which is not compensated for. What I need is for the trim settings to be updated periodically based on flight parameters. My main concern here is when the aircraft picks up the target tow there is a massive increase in weight, drag, and a strong pitch up moment. These need to be compensated for. I am working on a customization of xPlane to simulate the tow and cat launch.
    2. Might be a factor of the aircraft speed when it crosses the waypoint. Cruise speed on this is 80m/s.
    5. Need to have a way from the GCS to flush the APM waypoint memory that works.
    6. So what settings are required to get this working? Need to maintain constant airspeed at all pitch angles.
    7. Understood. Will try.
    8. What I was getting at is why not use the calculated wind speed and direction, derived from heading required to hold course and airspeed required to hold track speed (over ground) recursively to calculate heading and airspeed required to track course and maintain speed? This is how airborne GPSs do these calculations.
    10. Understood. reason for looking at opensource.
    11. Will try tuning yaw for takeoff and see what happens in flight. Note that in operation all takeoffs will be catapult so this shouldn't be as great an issue.
     Thanks again.
    jz
    Sorry, I renumbered the items when I posted to the list, skipping the ones that weren't issues. I hope you can figure it out from the responses.
  • Ok, this is the first post to Arduplane group so please bear with me.
    We are evaluating and testing autopilots for a high speed target drone, as in 200knot + and up to 10000ft alt. I have been working with an APM1 running Arduplane 2.4 in HIL mode with xPlane. These are some of the comments / concerns so far.
    1. Trim is a real pain in the ass. The aircraft trim changes dramatically during flight due to configuration changes, pickup of towed target, dropping target, gear retraction or extension, etc. Is there any way to automate the trim changes? As it is now, every time trim changes are required it has to be done either in manual mode and switch back to auto, or manually using parameter changes through telemetry.
    2. The autopilot appears to command a switch to loiter or circle after waypoint passage if the angle between programmed tracks is greater the 90deg. This behavior is quite consistent.
    3. One programmed flight to 5000m completely corrupted the APM settings in such a way that switching out of manual commanded a full power dive in all auto modes.
    4. What is the maximum airspeed and altitude. The aircraft we are testing is capable of far in excess of 100m/s cruise speeds and climbs at over 7000ft per minute. (yes, it is prop!)
    5. Waypoints don't seem to be written consistently. Saving waypoints to the APM some times (most times) does not overwrite existing waypoints or remove any in excess. This can be quite confusing since the aircraft takesoff in some apparent random direction that does not match the programmed route. Reading the waypoints shows the errors. This is a pretty major bug that needs to be addressed.
    6. During any auto mode, descents drop the throttle to idle but keeps the decent angle consistent (as it should) thus resulting in a drop in airspeed. The throttle should be managed to maintain a constant airspeed irregardless of climb or decent angle, within the capabilities of the aircraft of course. FWIW, the throttle increases to cruise setting with speed increase once the decent and level off is completed.
    7. Tracking a path between waypoints results in a snaking flight path. Tracking direct to a waypoint does not. Can't the same code be used for both?
    8. Where is current wind speed and direction as derived from GPS groundtrack vs. heading available on the GCS?
    9. Need to be able to specify loiter and circle direction as a parameter of a loiter waypoint.
    10. Is there any way to command landing gear retraction after successful takeoff and extension after passing last waypoint before a landing waypoint?
    11. The drone we are testing will use parachute recover and catapult launches. Is there anyway to set a waypoint to deploy the parachute.
    12. There needs to be a way to ramp up the throttle slowly on takeoff. Full throttle at low speed results in a hard turn to the left which is NOT corrected by the APM. Normal takeoffs with this aircraft are nearly impossible because of this (prop is 24x24 4 blade... i.e. LOTS of torque)
    The waypoint programming issue and autotrim (from flight data, not from RC settings) are really must haves for this to work for us. Any ideas if these can be added / fixed?
    Best Regards
    JZ
  • I have plank flying wing with two motors Left and Right on leading edge, and moving horizontal stabilisator back, without rudder and elevons.Radio is Futaba6EX with R617FS receiver.I use Futaba elevon mixing on CH1 and CH2 for diferential  motors control and CH3 for horizontal stabilisator control.
    Is it better for my flying wing to use Arduplane system with elevons mix, or Arducopter system ,tricopter version ,but vith control two motors and one servo for horizontal stabilisator.Is it possible  to make setap for this?
