ArduPlane home page
3689354430?profile=original
3689312509?profile=original
Convert any RC airplane into a fully-autonomous UAV!
Just add the APM 2 autopilot to any RC aircraft and it becomes a fully-programmable flying robot with a powerful ground station and Mission Planner.
Features include:
  • Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
  • Unlimited 3D GPS waypoints
  • Built-in camera control
  • Fully-scriptable missions
  • One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
  • Replay recorded missions and analyze all the data with a graphing interface
  • Supports two-way telemetry with Xbee wireless modules.
  • Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
  • Fly with a joystick or gamepad via your PC--no need for RC control!
  • Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
3689354391?profile=original
3689354242?profile=original
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
*  APM 2.5 autopilot with GPS ($179)
*  [Optional] Telemetry kit ($75).
3689354459?profile=original
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies!3689354440?profile=original (We're partial to the SkyFun delta wing (right) and
Bixlee 2   powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
    @johann - I believe there is a team that will be working on firmware for a single rotor heli. I don't know if that work has commenced.
    Uwe,
    The schematic has been on the product listing since it was launched (it's at the bottom)
    Jonathan,
    --The boards are all blue. Green was just the prototypes. We'll update the pictures shortly.
    --Sparkfun usually gets things back in stock within a week.
    --The IMU shield stock is also refreshed every week or so. Shouldn't be much longer...
  • I would love to get my hands on this but unfortunately SparkFun is out. About when can we expect the next batch of APM and IMU boards? Also, the newest IMU boards will be green right? It seems like there was a change in a gyro (http://www.diydrones.com/profiles/blogs/ardupilotmega-imu-shield) so all the pictures of the blues, including the DIYDrones Store one, are the older versions right?
    I am part of a team that is planning on competing in the AUVSI competition and we would love to use this setup.
    Tommy, there are three different kinds of memory on the chip, but the waypoints are stored in EEPROM right now. That's 4K. Given six bytes per waypoint (that's a lot, giving us lots of room for extra data fields), that's nearly 700 waypoints.
  • Hi, I am a newbie here.
    May I know the maximum number of waypoints to be used by this board? What is the internal memory size? Thanks in advance:)
  • @Doug: Sounds great! Where can I find the APM_RC, APM_ADC, DataFlash, and GPS_UBLOX dependencies?
    @Bryan - you can use the development code for testing the ublox. That functionality is in place. If the AP is receiving messages from the Ublox then LED C on the shield will blink. If it has lock then LED C will be solid. If LED C is off then the AP is not getting messages from the ublox.
  • We are considering using the Ardupilot Mega for the AUVSI competition next year. Is there an ETA on when the next batch of IMU shields will be available? Right now stock shows -10.
  • Is there a sketch for testing the uBlox on the AMP?
