ArduPlane home page
3689354430?profile=original
3689312509?profile=original
Convert any RC airplane into a fully-autonomous UAV!
Just add the APM 2 autopilot to any RC aircraft and it becomes a fully-programmable flying robot with a powerful ground station and Mission Planner.
Features include:
  • Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
  • Unlimited 3D GPS waypoints
  • Built-in camera control
  • Fully-scriptable missions
  • One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
  • Replay recorded missions and analyze all the data with a graphing interface
  • Supports two-way telemetry with Xbee wireless modules.
  • Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
  • Fly with a joystick or gamepad via your PC--no need for RC control!
  • Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
3689354391?profile=original
3689354242?profile=original
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
*  APM 2.5 autopilot with GPS ($179)
*  [Optional] Telemetry kit ($75).
3689354459?profile=original
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies!3689354440?profile=original (We're partial to the SkyFun delta wing (right) and
Bixlee 2   powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
  • Perfect fit for an easystar...need to level it and mount it.
  • if I use this board, do my receiver needs to add on the PPM?
  • Hi. if I'm using this board, do I need to use PPM encoder???
  • Oh yes, very handy to do a subversion checkout on this URL
    http://arducopter.googlecode.com/svn/trunk/libraries
  • @Dave...thank you very much! I didn't see them in the ArduPilot trunk.
    http://code.google.com/p/ardupilot-mega/source/browse/#svn/Trunk
  • @John C - how about here:
    http://code.google.com/p/arducopter/source/browse/#svn/trunk/libraries
    Doug is using these.
  • @Dave - I hope so....it was the only place I could find all of the libraries.
    These do allow me to compile and upload the code, but I must admit that I can't get it fully functional yet. I have manual functionality, but my CTRL isn't working yet....
    Still playing with it. Is there a better source for all of the necessary libraries?
    JC
  • Many thanks Chris. I really want to build my own UAV for search and rescue purpose. 700 waypoints are more than enough as my small RC plane cannot fly this long distance. If I want to install a small digital camera inside an UAV, can I assign ArduPilot Mega to command the camera to take photos at specific points? Waiting for the code for ArduPilot Mega:)
  • Hello, anyone knows when they will Didron SparkFun and the Mega Ardupilot IMU and shield? Thanks, greetings.
    Hola, alguien sabe cuando llegarán a sparkfun y didrones el Ardupilot Mega y el escudo IMU? Gracias, un saludo.
  • @John C - those look old - are they REALLY for the latest shipped hardware?
