Features include:
- Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
- Unlimited 3D GPS waypoints
- Built-in camera control
- Fully-scriptable missions
- One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
- Replay recorded missions and analyze all the data with a graphing interface
- Supports two-way telemetry with Xbee wireless modules.
- Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
- Fly with a joystick or gamepad via your PC--no need for RC control!
- Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies! (We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
I have my UBLOX GPS module connected and the C LED is flashing a steady red.
1. Does the APM use a Kalman Filter?
2. Is there some code available in addition to the pre-Alpha code that would be useful just for stabilization?
I'm looking for attitude indicator, heading, airspeed, alt, etc.
Just getting my system up and running and so far it passes all tests. Working on the Media Tek GPS now.... got it soldered to the adapter board, cabled up, blue light blinking.
Thanks Chris, Jordi and all the team members!
Newbie Beez
45
46
47
48
49
of 59 Next
