Features include:
- Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
- Unlimited 3D GPS waypoints
- Built-in camera control
- Fully-scriptable missions
- One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
- Replay recorded missions and analyze all the data with a graphing interface
- Supports two-way telemetry with Xbee wireless modules.
- Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
- Fly with a joystick or gamepad via your PC--no need for RC control!
- Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies! (We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
Steve
http://code.google.com/p/ardupilot-mega/wiki/Reversing
Try getting data using U-Center first to rule out a hardware problem. I am not a U-Center expert, but there are a few threads here about it.
i'm powering up by usb and battery at the same time. my imu Led B is getting a solid yellow. while my LED C is flashing .so i'm guessing i'm not getting any gps lock?
my U-Center is flashing dark green and light green, but i am not receiving any information about the location. i'm using baudrate 38400.
The current APM software uses libraries for all of the gps code. Please review the manual.
Powering the APM by USB may or may not supply enough power to get lock with your gps. It depends on how much power your computer will source through the usb cable.
30
31
32
33
34
of 59 Next
